where did you mount your flexfuel sensor
Old May 18, 2014 | 02:05 PM
lude92_si's Avatar
Default where did you mount your flexfuel sensor
Getting ready to mount my GM flex fuel sensor wanted to see some pics of where and how you tapped it in the return line.
Thanks
Old May 18, 2014 | 03:01 PM
passmans2kny's Avatar
the sos kit makes mounting the sensor a breeze
Old May 20, 2014 | 09:31 AM
riceball777's Avatar
I just cut some space out of the return line and let it hang there. It's not nice like the SOS setup but it works fine.
Old May 20, 2014 | 06:41 PM
lude92_si's Avatar
Any pics? I'm not even sure where the return line is under the car :/ haven't had a chance to look
Old May 21, 2014 | 06:15 AM
ScienceofSpeed's Avatar
The ScienceofSpeed FlexFuel Kit comes with a CNC bent mounting bracket to use an OEM mounting location. Check it out:
Old May 21, 2014 | 08:15 AM
APoner's Avatar
I was thinking of just cutting the return line a little after the fpr. Seems like the most easy place. That line has a lot of give when you route it away from the intake manifold the grommet. When you install the SOS base kit you take it from the oem location to where the brake booster is pretty much. So you definitely have slack there.
Old May 21, 2014 | 12:36 PM
james0933's Avatar
True
Old May 21, 2014 | 03:30 PM
1SlowSi's Avatar
Same area as passman minus the kit. Zipties ftw again.
Old May 21, 2014 | 08:30 PM
siadam's Avatar
That SOS kit is very nice. Wasn't there a kit out there, that came with a little digital display to show you ethanol content as well?
I would like to know what my % is with the different stations around. See if it warrants a tune first, alot easier to look at a gauge, then to mess with the cylinder to test on the spot.
Old May 22, 2014 | 04:13 AM
herecomesboost's Avatar
Zeitronix ECA:
http://www.zeitronix.com/Products/ECA/ECA.shtml
Dynosty:
http://www.dynosty.com/2012/06/new-e...-from-dynosty/
