where did you mount your flexfuel sensor
Old May 22, 2014 | 12:31 PM
siadam's Avatar
Originally Posted by herecomesboost
Originally Posted by siadam' timestamp='1400733058' post='23170648
That SOS kit is very nice. Wasn't there a kit out there, that came with a little digital display to show you ethanol content as well?
I would like to know what my % is with the different stations around. See if it warrants a tune first, alot easier to look at a gauge, then to mess with the cylinder to test on the spot.
Zeitronix ECA:
http://www.zeitronix.com/Products/ECA/ECA.shtml
Dynosty:
http://www.dynosty.com/2012/06/new-e...-from-dynosty/
Thanks.
Question about the SOS kit, does it tell you teh % in AEM for example? What does it output from the flex fuel sensor?
Old May 22, 2014 | 01:25 PM
ScienceofSpeed's Avatar
Former Sponsor
The ECU reads the frequency output from the sensor which allows the ECU to display ethanol content and fuel temperature. It can display this on a laptop or a display product that can read FlexFuel content, like gaugeART:
http://gaugeart.com/
Old May 22, 2014 | 08:42 PM
siadam's Avatar
Appreciate the reply, your kit is very nice, and I'd pull the trigger today if it could display it on a small digital device.
Something that was able to be hidden for example. I hate to be forced to hook up my laptop every time I put gas in the car to view the ethanol content, or spend an additional 500+ on something like guageart (no offense looks like a great product, just beyond my needs, and most for this simple sensor solution).
My car's tuned on e85, but in my area the % varies, and I'd like to know what I'm running before I go out and beat on it for a night.
Old May 23, 2014 | 02:51 AM
passmans2kny's Avatar
the zeintronics unit can be had for 200$, not that bad, and can be put pretty much anywhere, but what would I know I just throw money out windows
Old May 23, 2014 | 06:37 AM
siadam's Avatar
IS that display compatible with the SOS unit though is my question?
Old May 23, 2014 | 07:37 AM
lude92_si's Avatar
It should work with any flex sensor, I went with the GM sensor and harness. Was like 80 total. Then you just tap the signal wire into the gauge.
Old May 23, 2014 | 07:50 AM
im 99% is it, the display needs to get the info from somewhere, ill be using the sos sensor with the zeintronics display very soon
Old May 23, 2014 | 08:03 AM
OHclassic's Avatar
If the flex fuel sensor already knows the ethanol %, then Anyone know if you could use PLX as a read out ?
Old May 23, 2014 | 08:11 AM
herecomesboost's Avatar
Yes.
Old May 23, 2014 | 09:23 AM
lude92_si's Avatar
Ok just to make sure i want to tap my sensor into the line coming off the back of the fpr? That's the return line correct? So just follow it down under the car....
