CEL Code P0411 AFTER Valve Adjustment
Old Mar 29, 2010 | 09:17 PM
S2Kevinn's Avatar
Default CEL Code P0411 AFTER Valve Adjustment
CEL light came on after the 1st drive after my valve adjustment.
Just got my codes pulled today. That's the only code that comes back.
Any ideas?
Regards,
Kevin
Old Mar 29, 2010 | 11:54 PM
zeroptzero's Avatar
probably not mechanically related to the adjustment, but check the vacuum hoses on the air injection system they may have been knocked loose or disconnected during the work. Some lines run along the back of the intake box. There is also the solenoid that mounts on the intake box, perhaps the electrical connnector was disconnected if the intake box was removed during the adjustment.
The worst situation would be a dead air pump, check the fuse for it.
Old Mar 30, 2010 | 06:11 AM
superchrgds2k's Avatar
Old Mar 30, 2010 | 11:01 AM
starchland's Avatar
be sure to reset your ecu.
Old Apr 2, 2010 | 12:34 PM
S2Kevinn's Avatar
I'm going to check over all of that stuff today.
In any case, I found this service bulletin.
http://ww2.justanswer.com/uploads/HondaCB7..._200503_411.pdf
I guess my main question with service bulletin would be, does Honda cover the parts and labor? Or are service bulletins just a means of telling people what's wrong with their cars and how to fix it?
Also, I did forget to mention that I do have a test-pipe on the car. Could the 02 sensor on the cat be throwing this code?
Regards,
Kevin
Old Apr 2, 2010 | 02:01 PM
RedY2KS2k's Avatar
Originally Posted by S2Kevinn,Apr 2 2010, 03:34 PM
I guess my main question with service bulletin would be, does Honda cover the parts and labor? ...
On a 10-year old car?
Old Apr 2, 2010 | 02:22 PM
seoul2k's Avatar
i called multiple honda dealers and they said NO lol.... if its out of warranty even a good faith fix is not possible. They're getting stingy
Old Apr 2, 2010 | 04:26 PM
Neutered Sputniks's Avatar
There are 2 or 3 other CELs that would pop up if the pump itself is bad.
It's your vacuum lines. Double check that they're all connected properly.
Old Apr 3, 2010 | 12:34 PM
S2Kevinn's Avatar
Just took a look-see and found that one of the lines got disconnected from the air control solenoid valve.
I put it back on temporarily, but should why type of sealant should I but putting on the connection?
It was #6 in the above image.
Regards,
Kevin
ChaseBaciles
Aug 4, 2020 08:05 PM
Billman250
Jul 23, 2016 07:07 AM
ChaseBaciles
Sep 26, 2010 09:51 AM
infinitebass
Oct 13, 2002 07:19 AM
