ignition Relay ?
Old Mar 7, 2011 | 09:14 AM
armas2k's Avatar
Default ignition Relay ?
hey wassup guys, hope everyone is well! so this weekend i encountered a promplem w.MY AP1 it wont start and i did a test my starter is not bad and my ignition switch it is giving out the power needed, so? my question is do the ap1 s2000 have an ignition relay ? and if so what does it look like cause my car doesent have the graph for the Relays ??
Thanks
Old Mar 7, 2011 | 09:53 AM
SgtB's Avatar
Is your clutch switch working? Do the gauges and everything else light up with the key in the on position?
Old Mar 7, 2011 | 11:27 AM
armas2k's Avatar
yes everything else works ! and yeah the clutch switch is working but theres a fuse called the "starter signal" its not blown but there is no power getting there either !
Old Mar 7, 2011 | 05:39 PM
oth's Avatar
oth
The "starter signal" circuit tells the ECM the the starter is powered, so no surprise the
there is no power there if you have no power getting to the starter. The starter cut relay
is in the under-dash fusebox - it's the middle of three relays in there, though if you have
no rear window defroster one of the sockets will likely be empty.
The circuit basically goes like this:
from the battery, through fuses 41 & 42 (under-hood) to the ignition switch.
from the switch, from one terminal to the starter cut relay, from another through the #3 fuse
(under-dash) to the start button.
from the start button to the starter cut relay coil, which is grounded through the clutch
interlock switch.
So basically, if I'm reading the wiring diagram correctly, when you push the start button,
the relay coil is energized if the clutch interlock is closed, and the + from the ignition
switch to the relay heads on to the starter solenoid.
ryiin2
Apr 23, 2018 05:19 PM
TakeshiS2K
Sep 28, 2016 10:29 AM
BS2K00
Feb 2, 2016 07:33 AM
RobbiecakesS2K
Jul 19, 2014 11:22 AM
mec
Nov 13, 2002 02:31 PM
