Clutch fork install
Old Aug 1, 2011 | 11:21 AM
armthehomeless's Avatar
Default Clutch fork install
Just finished an engine swap, but I had no clutch fork, I installed the engine after reading Here that you can remove the clutch fork tranny in place, and now for the life of me , I cant get the clutch fork in.... Tips tricks anyone? I've even tried turning the engine a bit. I really don't want to pull off the transmission....
Old Aug 1, 2011 | 11:49 AM
s2klariat's Avatar
As far as I know you CANNOT remove or install the clutch fork with the transmission mounted to the engine.
Old Aug 1, 2011 | 11:56 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Pull the trans.
I have seen one case where a guy forced it in there, and broke the transmission case.
Old Aug 1, 2011 | 02:17 PM
ahrmike's Avatar
You don't have to pull the trans off all the way - crack the trans open, dont remove all the way or its a PITA to line up. It'll fit - dont force it, just wiggle it around until it fits nicely. I forgot to insert the clutch fork before lining up the trans/slapping it together.
Old Aug 1, 2011 | 03:29 PM
Slows2k's Avatar
you have to separate the trans from the engine to get the fork in, make sure the fork is facing the correct direction.
Old Jan 8, 2013 | 02:28 PM
boosteds2k03's Avatar
How far apart does the tranny got to be from the block for it to fit?, did about 1 inch still wont go in.
Old Jan 9, 2013 | 06:36 AM
4forall's Avatar
Pull the trans. You will just cause yourself more issues down the road. Not to mention its hard to grease it w/o pulling the trans as well.
Billman & Slows2k say it, you do it!
Old Jan 9, 2013 | 04:59 PM
alphalanos's Avatar
I accidentally wiggled the fork loose when I was polishing the slave cyl rod end. i was in shock but I guess it didnt come all the way out as I was able to move it back into place and it works fine,
Old Jan 9, 2013 | 05:38 PM
zeroptzero's Avatar
the fork can be pulled out of it's holder and reinserted without issue , that's the only way to get it on the release bearing when installing the tranny. Your experience is normal.
merkis1024
Aug 26, 2014 05:45 PM
124Spider
Nov 8, 2007 01:23 AM
LuckyStar
May 5, 2007 01:57 PM
Partshelper
Oct 26, 2006 12:03 PM
skinny finger
Oct 22, 2003 08:31 PM
