AEM EMS V2 startup issue
Old Sep 8, 2011 | 08:33 AM
Metcalfe's Avatar
Default AEM EMS V2 startup issue
First off I am fairly new to AEM so bare with me...
I have the car running pretty good aside from initial startup. The car cranks a bunch of times before it will fire. When it starts up it runs great.. what would I need to change to address this problem?
Old Sep 8, 2011 | 08:55 AM
Round 3's Avatar
pm me. I'll check out your map
Old Sep 8, 2011 | 11:51 AM
Metcalfe's Avatar
Running the stock 04 AP2 map on a stock car.. just getting the hang of things. Took 5% out of the entire map to conpensate for the slightly smaller motor.
Old Sep 8, 2011 | 11:58 AM
jh4db536's Avatar
I wrote a thread specifically about aem start up tuning its a little out of date but you'll get the idea
I am still learning and tweaking it myself, but I think I hit a wall as far as improving. I hear from experienced tuners that a difficult cold start is normal. I can start the car in one try everytime after sitting overnight but it still requires substantially more than stock cranking.
I want to see how fast other people have gotten their cold starts with the ems. I don't know very many people with the aem though.
Sent from my T-Mobile G2 using Tapatalk
Old Sep 8, 2011 | 12:07 PM
Metcalfe's Avatar
I heard that this was more of a problem with the 1052.. this is one of the reasons I went with the Series 2.
Link to your thread?
Old Sep 8, 2011 | 12:37 PM
Round 3's Avatar
mines start about half a second later then factory. give me a pm and ill help you
Old Sep 9, 2011 | 09:37 AM
fmfkid250's Avatar
Whats is your voltage reading at startup. My car had a messed up main relay and I was only getting 9.2-9.8V during cranking.
Those coils dident even want to work at that voltage level...
Old Sep 9, 2011 | 10:01 AM
jh4db536's Avatar
Between 10.5 and 11v
I'm sure its not an issue for me because the car eventualy starts if I keep cranking and the voltage will drop further under continuous cranking. My battery is strong.
David suggested to me that I play with battery offset table, so I'm going to try that.
Old Sep 10, 2011 | 02:03 AM
s2knoob89's Avatar
When I start my car I have to let the fuel pump finish priming to start the car right away. If I try to start the car before the pump is done priming it will crank forever (4-5 seconds) then start.
Old Sep 10, 2011 | 07:57 AM
jh4db536's Avatar
I always let the fuel pump prime before starting. I even programmed so that it primes a little extra. I hear it prime then I push the start button immediately after.
I thnk I found the solution though. I added up all the different fuel trims (based on coolant temp) at different temperatures and compared them on paper. I have Huge swings between 20c and 60c...like +13% at 20c and -3% at 60c. The warm up enrichment accounted for most of this swing so I flattened the curve out a bit and things radically improved.
It makes sense that my car starts so easily when warm. Yet its got too much fuel when cold and when I lower the fuel I lose the good warm start
heist
Jul 28, 2014 05:12 AM
EK9MAX
Feb 15, 2010 04:49 PM
djap1
Mar 29, 2007 05:03 AM
dark_gap
Feb 6, 2007 04:13 PM
Nhan
Dec 6, 2006 08:08 PM
