AEM basemap would start car....
Old Nov 22, 2009 | 05:25 PM
EK9MAX's Avatar
Default AEM basemap would start car....
Ok I got a 2003 ap1 w/ 3mm HG. gt35r turbokit install also.
Running stock injectors/map sensor for now to get it to teh bodyshop.
Anyways. Stock ecu starts and runs car like stock (except when it sees a touch of boost it bucks like a horse)
Plug in the aem, load aem basemap.... doesn't start.
I've tried aem v1 and V2...... neither basemaps/ems work....
Old Nov 22, 2009 | 10:52 PM
CKit's Avatar
Is this your first exposure to AEM (I'm assuming EMS).
It's notoriously finicky on cold start. It's one of the reasons I'd do K-pro or FlashPro given the chance.
Old Nov 23, 2009 | 04:33 AM
Sikocivic's Avatar
Just don't hook the intake pipe to the turbo. Put a screen or cheap air filter on your TB and drive it to the body shop. Let the turbo just blow the air out. I drove my turbo Civic like this for 500 miles to break in a new motor. Drove it to the tuner and swapped in the bigger injectors and new ECU and had it tuned.
Old Dec 2, 2009 | 07:00 PM
EK9MAX's Avatar
does that really work?
Old Dec 3, 2009 | 02:18 AM
Hondata's Avatar
Former Sponsor
Running the turbo discharge to atmosphere will potentially over-speed the turbo.
Wire the wastegate open so the you don't build boost and drive the vehicle with stock injectors.
Old Dec 3, 2009 | 09:58 AM
Gernby's Avatar
Former Sponsor
I bet that will sound nice!
Old Jan 31, 2010 | 06:40 AM
ap1tuner's Avatar
yes, please god dont drive your car anywhere with the turbo disconnected. it WILL blow your turbo. it never sees boost, so it keeps spinning faster trying to get up to boost and never gets there. i had a friend who blew TWO turbos this way. (i have no clue why he did it twice)
Old Jan 31, 2010 | 10:54 AM
s2k dre's Avatar
A gt35r shouldnt be hard to drive without boost. It wont spool that fast, just drive the car with everything hooked up and dont boost.
Old Feb 3, 2010 | 05:12 PM
Tech7427's Avatar
the aem basemap wont start the car. you have to scale the injectors and adjust crank injector time table.
Old Feb 15, 2010 | 04:49 PM
theblackpearl's Avatar
you're not suppose to be light on a new engine for break in. you need to run it to redline and let it coast back down to properly set the piston rings and suck out any metal shavings.
heist
Jul 28, 2014 05:12 AM
buzz944
Oct 24, 2012 03:57 PM
Metcalfe
Sep 10, 2011 07:57 AM
Moddiction
Apr 28, 2010 07:32 AM
Nhan
Dec 6, 2006 08:08 PM
