HELP NEEDED! Drive train Delay when accelerating
Old May 19, 2012 | 11:48 AM
EssToOfouzEn's Avatar
Default HELP NEEDED! Drive train Delay when accelerating
I'm experiencing a delay from the time the accelerator is pressed to the time the car starts to move. The car seems to dive after the gas is pressed before it starts to hesitate and finally moves and this happens in any gear any speed. I would say there is a good 1 second delay from the time I press the gas to the time the car actually accelerates ( this is the best way I can describe the problem ). The problem has gotten worse since i noticed it a couple of months ago
I checked the motor mounts so far and the are still good..
Any ideas what the problem could be? any suggestions would be greatly appreciated
thanks guys, cheers
Old May 19, 2012 | 11:53 AM
DFWs2k's Avatar
Do the rpms rise? What year is your car?
Sent using free Tapatalk - Android FTW
Old May 19, 2012 | 11:59 AM
car is a 2006. the rpms dont rise but i do file like a knock sometimes almost like something engaging... its weird
Old May 19, 2012 | 02:36 PM
sata3000's Avatar
Injectors may need to be cleaned
Sent from my SPH-D710 using Tapatalk 2
Old May 19, 2012 | 03:24 PM
I think I'm not explaining the problem correctly its kind of hard... so here is a scenario; I'm on third gear cruising at about 35 MPH and I decide to step on the throttle and release, the car would sort of knock back and forth as if I was starting in first gear and bogged out....it will also have this drive train "shock" when sudden acceleration occurs.
Old May 19, 2012 | 03:31 PM
dra9on's Avatar
drive by wire?
Old May 19, 2012 | 04:22 PM
I think its a mechanical problem underneath but not sure where to start. I highly doubt its something electrical but my assumptions could be completely off.
Old May 19, 2012 | 05:13 PM
S2KIrishman's Avatar
Originally Posted by dra9on
drive by wire?
exactly what i was thinking...exact reason i will never own a 06+ S2K...i dont give a shit what anyone says about not being able to tell, because when i drove an 06 and an 07 on two seperate occasions, i could def. tell...not a fan of any sports car that is DBW, dont care how fast it supoosedly reacts...a computer will never govern my inputs as a driver...i dont even like abs and if there was an easy way to take it off my car without it being a hassle, that would be gone too
Old May 19, 2012 | 05:16 PM
spets's Avatar
Yeah I wouldn't say it is drive by wire as that is well implemented on these cars.
Run a fuel injector cleaner like BG44K through the car. clean/replace the PCV valve. Maybe clean the throttle body and MAP sensor.
Old May 19, 2012 | 05:19 PM
wouldn't there be some sort of a check engine light on? because currently I have no codes coming up
kondata
May 22, 2014 06:53 AM
stwokayyy
Jul 1, 2010 12:22 AM
Hiroprotaganist
Jun 24, 2010 01:37 PM
S1999+1
Apr 10, 2004 07:30 AM
jyce
Sep 21, 2001 06:41 AM
