motor seized
Old Apr 16, 2006 | 09:58 PM
aguilars2k's Avatar
Default motor seized
My 01' s2k motor seized at 48,151 miles what the hell?
i was on the highway running at about 60-65 MPH
my engine made a bogging sound and lost power completely.
so as soon as i felt and herd that something was wrong i let the car go on Neutral i try and put it back in gear so i can atliest make it to the off ramp and park at a gas station..... well the car just made it to a complete stop i pop the hood to check if their was any kind of liquid leaks witch i didn't see any.... the oil was fine the water was good as well ..... so about half an hour later i try to start it again it starts but it wont keep running unless we accelerate the throttle just enough to keep it going we kept it running for like half a minute shuts off ----- we try once more and now it's starts for about .05 seconds we herd a sound like the timing chain got caught or rapped around something ...... and bam the motor just stops never started again ....
i don't have any idea what went wrong my warranty is out .......
what could it be....?????
*we towed the car home now that the car is in my garage we took the engine apart to see if it was the timing chain but it wasn't
*drained the oil to see it it had water the oil was clean.
*we checked the spark plugs and they where completely dry .
we tried to turn over the engine forward and back but it gets stucks....
does any one have any idea or similar problems....like mine
hopefully i provided enough detail so anywho reads this will understand....'
if not ask....
thanks for reading
EDWARD AGUILAR.....
Old Apr 16, 2006 | 10:11 PM
newspeed's Avatar
drop the oil pan and take a look in there... you could have a broken connector rod, maybe not... once you drop the pan you can look up and see whats preventing it from turning...
Do have any movement at all or it completly seized? if you have a little movement you can pull the plugs, stick a screwdriver long enough to reach the pistons and try to turn to see if the all the piston move...
could be a number of things, broken rod cap, something broke and got lodged somewhere near the crank, etc...
Have i mentioned dropping the pan to take a look?
Old Apr 16, 2006 | 10:13 PM
s2kBryan916's Avatar
What does that sound like?
Old Apr 16, 2006 | 10:19 PM
oakfloor's Avatar
Was there any noticeable metal shavings in the oil? did the anti-freeze smell funny? ,how much oil came out? pull the plugs and scope out the cylinders for scoring, oil pump quit? oil filter clog? how many miles on the oil filter? was it the correct filter? what oil ? and keep us posted when you find the cause.
Old Apr 16, 2006 | 10:47 PM
aguilars2k's Avatar
no oil leaks , no funny smells
when we dropped the oil pan their was no metal shaving at all.
what it sound like : it sound like aluminum rattling for a split second and never started again..
i spoke to my father and he said that mabe the oil pump went out and wasn't returning the oil ..... "OIL PUMP QUIT" like OAKFLOOR said it's mabe
yes of course i will post daily my father will be working on my car wile i am at work but every time i get a chance after he scopes the engine out i will keep you all updated ............
if i don't reply tonight anymore i will when i get off work after another 15 hour shift..........
thanks everyone once again.........
Old Apr 16, 2006 | 10:52 PM
RACER's Avatar
spun bearing?
Old Apr 17, 2006 | 05:58 AM
Squeezer's Avatar
dropped a valve into the combustion chamber? the retainers are known to stretch and if they fail it will drop a valve
Old Apr 17, 2006 | 07:33 AM
Bolt Upright's Avatar
Just a wild guess since I don't have access to the manual here at work, but I'd definitely look at the timing chain guides and/or tensioner(s). I'm guessing what you heard was chain slap. If a guide or tensioner broke inside the front cover, that would explain why you're locked up tight.
Old May 1, 2006 | 01:44 PM
aguilars2k's Avatar
GUYS , I havn't figured out the problem with my s2k.
I been real time tight , lots of over time at work witch, I am not complaining about. I could use the money from over time hours to get my car up and running again.
s2k still down.......
what could it be??????????
very stressfull
hope no one has the problem i am having .....
Old May 1, 2006 | 03:04 PM
NFRS2kSi's Avatar
well.... only way to find out is get to the source... pop the head out.
