motor seized
Originally Posted by aguilars2k,May 1 2006, 01:44 PM
GUYS , I havn't figured out the problem with my s2k.
I been real time tight , lots of over time at work witch, I am not complaining about. I could use the money from over time hours to get my car up and running again.
s2k still down.......
what could it be??????????
very stressfull
hope no one has the problem i am having .....
very stressfull
Originally Posted by aguilars2k,May 1 2006, 03:16 PM
THE CONTAMINATED FUEL JUST RUNG A BELL ON ME
about 7 miles before this happend i had just fueled at this tom thumbs gas station
could it be a possiblity?
If you filled it with deisel fuel it would have a white smoke from the exhaust pipe.
If there is water in the fuel the engine would not run (just like you are describing).
You can remove the cam cover and do a visual check of the timing chain, tensioners, etc.
Also, you can do a compression test to see if you have valve, piston, or cylinder damage.
Originally Posted by stitos2k,May 1 2006, 05:04 PM
I'd guess timing chain or contaminated fuel... Sugar for example will lock an engine up tight. You sure someone didn't pull an EXPENSIVE prank on you?
