Key Torque and Volume Specs
Old 11-16-2007, 01:29 PM
Bob A (SD)'s Avatar
Default Key Torque and Volume Specs
Here's some key torque and volume specs that I find handy
--80 lb-ft wheel lug nuts
5.1 qt engine oil
--29 lb-ft drain plug
--16 lb-ft oil filter
1.56 qt transmission fluid
--33 lb-ft filler plug
0.78 qt differential lube
--33 lb-ft drain plug
6.9 qt radiator coolant
These are from the AP1 shop manual.
Thanks NVMY4N. I added the note above about AP1.
Split and Edited Title
Old 11-16-2007, 03:10 PM
NVMY4N's Avatar
Red face
I split this info from Here, to sticky them.
Old 11-27-2007, 07:09 AM
rugsr's Avatar
doing a spring install, anyone know the tq specs for some of the bolts ill be taking off?
Old 11-27-2007, 08:46 AM
froggie's Avatar
Spark plugs: 18 lbs-ft
Old 12-08-2007, 07:20 PM
NVMY4N's Avatar
Originally Posted by Twiztid,Dec 8 2007, 07:29 PM
For Tranny Bolts
94 ftlbs for the flywheel to crank
19 ftlbs for the pressure plate to flywheel
All the larger Tranny bolts are 47ftlbs ( 17mm socket )
The two bottom smaller ones are 33ftlbs ( 14mm Socket)
The three that hold the cross member under the shifter are 28ftlbs (14mm socket)
The front subframe .. the four larger ones are 86ftlbs ( 19mm socket ) the two smaller ones are 43ftlbs ( 17mm socket )
All the 6mm ( 10mm socket) around the shifter boots top and bottom are 7 ftlbs
The 8mm drivshafts bolts 24ftlbs ( 6mm allen )
Old 03-13-2014, 07:37 AM
Reckon's Avatar
Anyone know the torque spec for the caliper bolts to the control arm? I am replacing my rotors and wanted to check what I should torque those bolts back to.
Old 03-13-2014, 08:22 AM
gptoyz's Avatar
Thats the upright the caliper mounts to or the knuckle. The control arms mount to the upright or knuckle
And the value is 79.6 ft lbs
Sent from my iPhone using Tapatalk
Old 03-13-2014, 08:23 AM
gptoyz's Avatar
I get my values from this post a bit more comprehensive
Torque Specs - S2KI Honda S2000 Forums : https://www.s2ki.com/s2000/topic/500969-torque-specs/
Old 03-13-2014, 09:43 AM
Reckon's Avatar
79.6 it is, thank you!!!!
Classic JDM
02-27-2017 12:14 PM
Yeaimpersian
07-14-2011 07:27 AM
JSR_AP2
12-04-2004 03:46 PM
Prancing Horse
03-21-2004 04:00 PM
SaV
10-28-2001 04:18 PM
Quick Reply: Key Torque and Volume Specs
