Front Fender Roll without Cutting Liner
Old 08-12-2016, 07:02 AM
roel03's Avatar
Default Front Fender Roll without Cutting Liner
Just rolled my fenders this morning and figured I would share my plan. I read the DIY and it was suggested to trim the liner around the fender tabs. I didn't really want to do that as I like an OEM look so this is what I did.
1. Removed the top 3/4 clips that hold the liner on.
2. Rolled the fenders with the liner still over the lip of the fender. I did not move the liner out of the way.
3. When rolling was done, I tucked the liner inside of the rolled lip, then gave it a couple more passes to lock it in.
The liner sits higher up than stock, looks completely stock because I didnt cut anything, and it doesn't sag at all. Got rid of rubbing on my 17x9+63 advans with 255 RS3s.
Here are some pics:
Old 08-12-2016, 08:04 AM
s2000Junky's Avatar
Old 08-12-2016, 09:16 AM
EricJT7's Avatar
Nice work, I wish I trusted myself to roll the fenders on my S2000.
Old 08-12-2016, 10:40 AM
Langelo DeMysterioso's Avatar
roll 'em up
LOL
Nice job.
Old 08-12-2016, 11:58 AM
Site Moderator
Manga_Spawn's Avatar
Nice. The part where it bulges will likely rub on the tire. Thats the only reason I trim that part. I'll add this to the fender rolling tips sticky.
Old 08-13-2016, 04:19 PM
Bullwings's Avatar
This is the kind of roll that you need to do if you want to be auto-x STR rule compliant. You can roll fenders, but no pull, and must keep fender liners in tact.
Old 01-19-2017, 08:54 PM
S2000_916's Avatar
On my passenger side I did it by removing the fender liner. Then I found this thread and thought why not try it this way as it seems like the better way to do if your rims and tires will allow it. I didn't go too aggressive but it definitely rolled it an ok amount.
Old 01-19-2017, 08:55 PM
S2000_916's Avatar
That pic was my driver fender with the picture to the front of the car
jdmdohcpower
03-05-2013 06:38 PM
smallville160
Tampa
16
05-22-2011 05:38 AM
svencarlson07
18
03-31-2010 07:54 PM
jon3501447
03-05-2010 09:02 AM
pikkashoe
05-03-2006 05:57 AM
Quick Reply: Front Fender Roll without Cutting Liner
