Windscreen Washers not working
Old 06-08-2019, 03:19 PM
  #21
martin j's Avatar
Last time recently I had bother with the jets I removed both. Jets, valves short hoses etc back to the single hose from the pump, add malt vinegar to hot water in a mug/glass and steep after agitating them, I would drain the water tank and put some hot water in with a little Milton sterilising fluid in if possible and operate to clean the system, when rebuilding fit one bit at a time from the supply pipe checking the flow as you go, too much screenwash can turn to goo blocking the system especially if not used frequently. HTH.
jdmdohcpower
03-21-2016 10:34 PM
Dhaval85
01-02-2013 04:05 AM
ross_gerry
05-04-2011 01:35 AM
GDM S2K
02-19-2009 03:21 AM
Widebodys2k
12-06-2006 03:11 PM
Quick Reply: Windscreen Washers not working
