oem high level spoiler install
Old 02-07-2016, 12:30 PM
aliendoughnut's Avatar
Default oem high level spoiler install
After purchasing the high level oem spoiler from a fellow member, getting it resprayed to the correct colour I now have the task of fitting it. I have read relating threads and the web so i know what to do. my question is has anyone else fitted one? I want to replace the washers circled in purple on the pic. what would be the best replacement? also i want to use double sided tape in the areas marked in blue. in addition to the bolts, there was a foamy substance covering the inside area which has been removed as it was falling off so i think padded double sided tape would be best as the inside is recessed. Any tips or advice would be appreciated...Thanks
Attached Thumbnails oem high level spoiler install-spoiler-1.jpg   oem high level spoiler install-spoiler.jpg
Old 02-08-2016, 12:53 AM
noodels's Avatar
They are part of a <swaging nut>
would need correct tool to replace correctly.
Old 02-08-2016, 01:03 AM
Originally Posted by noodels
They are part of a Rawl nut or jack nut insert,
Ok I thought they were just a thin rubber washer looks like I will be better off just leaving them
Old 02-09-2016, 07:06 AM
jcunningham's Avatar
Probably be useful getting the installation instruction manual from Honda.
This was an accessory you could buy from the dealer. Most dealers in their computer have the instruction manual for this part. It will tell you all you need to know. Call around, and make sure they understand you are talking about the rear wing, not the rear spoiler.
The manual might be on the web also. Do a google search. Find out the exact name that Honda called this, you know how they give things weird names sometimes.
Old 02-09-2016, 10:02 AM
barnabylee's Avatar
Here you go, https://www.handa-accessories.com/S2000/04s2kwing.pdf
Old 02-09-2016, 01:39 PM
Originally Posted by barnabylee
Thanks barnabylee i also found a template pdf for getting the holes in the right place. I just need to find a replacement for the 4 o rings, I tried a honda dealer and even gave them the part number but they only sell the entire spoiler with the bolts washers etc as a full kit and not separately also just need a cordless drill and a steady hand
Old 02-09-2016, 10:29 PM
davidc1's Avatar
Originally Posted by aliendoughnut
Any hardware store here in the states usually has lots of Orings. There are also many, many online sellers of things like o rings.
Old 02-10-2016, 03:47 AM
Originally Posted by davidc1
Originally Posted by aliendoughnut' timestamp='1455057594' post='23876129
[quote name='barnabylee' timestamp='1455044533' post='23875898']
Here you go, https://www.handa-ac...0/04s2kwing.pdf
[/quote]
yes we also have places that sell o rings here in the uk too my initial query was to make sure I got the correct thickness of o ring. but thanks for your words of wisdom
aliendoughnut
03-06-2016 03:55 AM
S2KnLA
11-06-2010 01:42 PM
zerospel
06-01-2006 05:30 PM
JMark
11-15-2001 05:04 AM
Quick Reply: oem high level spoiler install
