transmission stuck on motor
I removed all 7 bolts around the bell housing and the top starter bolt. the throwout fork is disengaged and the driveshaft is off, all exhaust is out of the way. I can get about a 1/4 inch gap on the bottom using 2 pry bars on either side of the case. it never opens up at the top of the case. Is the main shaft stuck on the disk or is it a stuck guide pin? any input would be great, thanks.
3 short bolts with 17mm heads, go through trans and thread into engine
3 long bolts with 17mm heads, go through engine and thread into trans
2 on the bottom with 14mm heads
1 starter bolt with 14mm head
Make sure you actually got the TOP starter bolt, you can see it from the driver side if you got the right one or not. That's what got me last week when I took my trans out lol. If not I have no idea.
I ended up removing the other starter bolt and broke the starter loose and it slid right off, Hardest part of the clutch swap aside from removing the transmission was reinstalling the slave cylinder, nothing to hold it compressed while you run the bolts in makes it kindve tricky
Norccer
08-01-2018 01:08 PM
darcyw
10-08-2017 06:49 AM
