What's proper torque spec for wheel nuts?
After a caliper painting job, I put the wheels back on. Then I used a torque wrench to tighten all wheel nuts to 80 f.lbs of torque.
Can anyone verify if this is correct torque spec for wheel nuts?
I simply followed the spec in owner's manual in the section where it tells you to tighten the nuts on the spare to 80 f.lbs.
I wonder if I should use different torque spec for full-size stock rim.
Your reply will be appreciated
80 lb-ft is correct.
FRFR
30
04-09-2004 05:05 PM
