high beam problem
high beam problem
hi i have a problem with my high beams not workin on my head lights on a ap1. the low beam hid still works but the high beam wont turn on. when i pull the stick back for a quick flash... nothing or when i push it foward to keep them on... still nothing. the blue high beam indicator doesent even light up on the dash... i thought it was the bulbs but they look brand new still. then i thought it was a fuse. but i couldnt find it. then i found out that we have relays... they seems to be workin. has anyone ever had this problem with an ap1?.... any help here would be great.
I have almost the same issue, except my high beam light on the dash will light up but nothing happens.
At the same time my DRL's stopped working . These were wired in aftermarket using a HAMSAR module. I think the DRL module/wiring came loose during some bumpy driving.
Idk bout you guys. But for me, the light on the dash wouldn't light up blue and high beams wouldnt turn on. What I did to end up fixing it was I had to replace the controls/ stick handle that controls the lights. I had aftermarket high beams bulbs in yellow that were a lot higher wattage and it ended up melting/ short circuit the left handle light controls. After replacing it. it worked just fine again. Hope that helps...... My guess is tho what ever aftermarket connected to your drl is causing it.... Good luck .
