Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
Got a check engine light
Old Jul 2, 2012 | 07:03 PM
AZ-S2000's Avatar
Default Got a check engine light
Driving and popped up. Went to AutoZone to check what it was and said it was an O2 Sensor, just didn't say if it was downstream or upstream or maybe the employee forgot the mention it. Anyway to find out using better scanning equipment? I am sort of relieved it was an O2 sensor because it was going through gas a lot.
Old Jul 2, 2012 | 08:26 PM
Boofster's Avatar
The o2 sensor is a part that fails often on our cars. Even more on '06+ models.
Find out if it's the primary or secondary and hit up Ben or cheapo aftermarket part.
If you have a test pipe, you will need a better spacer.
Old Jul 2, 2012 | 10:36 PM
AZ-S2000's Avatar
Is that his name on here? I'd like to go OEM unless it doesn't matter. I was also considering Bosch but was advised not to by someone on here and said to stick to Denso's.
FrontRowForward
Sep 22, 2013 11:46 AM
__Ap2__s2k
Jun 12, 2013 02:23 PM
f20cpower3
Apr 15, 2010 01:14 PM
01SSAP1
Sep 6, 2007 07:27 PM
demonderrick
May 19, 2003 11:25 PM
