Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
help camber bolt ?
Old Apr 20, 2013 | 07:48 PM
*s2k408*'s Avatar
Default help camber bolt ?
So im trying to run some negative camber but only my right side cambers in my driver side doesn't camber in was wondering if any one has had that problem before.
Old Apr 23, 2013 | 06:32 AM
berny2435's Avatar
are you actually doing this adjustment yourself?
ARe you talking about front or rear?
IF you are doing this yourself, are you watching the lower a-arm move in and out as you rotate the bolt and confirmed that one side moves and the other does not?
http://robrobinette.com/S2000Alignment.htm
Read through the above site carefully and let us know if you are adjusting the correct bolt. If you are having troubles rotating it, raise the car and pull the wheel. make sure the nut is backed off and start to rotate the bolt which has the lobs on it. If it wont rotate, spray some PB blaster on it or something. If that does not work, put a socket you don't care about over the bolt head and bang it with a hammer.
GL
hoobastnk90
Apr 18, 2018 07:01 AM
2004TurboS
Apr 4, 2014 01:36 PM
KUpton83
Mar 21, 2014 08:57 AM
c.tran
Aug 18, 2012 11:15 AM
adz9
Feb 28, 2008 06:41 AM
