Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
Motor Help
Old Mar 21, 2010 | 09:14 PM
3en's Avatar
3en
Your right. I guess they started the 5/60 in 06. That does suck.
Old Mar 21, 2010 | 09:23 PM
1FastS2k's Avatar
Again, sorry about the car. So do you think it's a bent valve?
Old Mar 21, 2010 | 09:26 PM
ZeroF's Avatar
Im not even sure to be honest, I am thinking I want to try and do a valve adjustment next and then try compression check again? Should I even bother?
Calling SOS tomorrow and asking them what they think.
Im open to ideas.
Trying to get money together for a possible motor rebuild or buy a used motor or buy a beater car / truck and rebuild my s2k.
So many different options.
Where to go from here I am not sure what do you guys think I should try next?
Old Mar 21, 2010 | 09:38 PM
watchdogd's Avatar
dumb question but what normally causes a bent valve ?
Old Mar 21, 2010 | 09:52 PM
3en's Avatar
3en
9/10 its a foreign object(piece of metal,water, shop rag, etc..) coming in contact with the valve and the piston. Other times it is an overrev, the timing chain jumping teeth, or the valve spring being really loose and it comes in contact with the piston.
Old Mar 21, 2010 | 10:10 PM
HWY88's Avatar
Well the 180 psi on number 1 is way above the acceptable 10% variance between cylinders.
At this point you need to do a valve adjustment on that cylinder only.
recheck compression, still bad? put a couple cap fulls of new motor oil into the cylinder and recheck compression. If it goes back up to normal bad rings. Still low, its gonna be a bent valve more then likely.
Assuming compression doesn't go normal with the oil trick. The head is going to need to be redone on cylinder 1 at least. $20 per valve x4, S2K tend to burn exhaust guides early so take this opportunity to replace all of them with upgrades $95, $80 in gaskets, $350-$450 in machine shop labor to get the head to a minty status. $700 total if you do it yourself. Have a shop do it and your looking at $1750-$2000.
Just want you to know what your looking at, been here done this.
Checking the piston face for damage will be necessary as well. Unless its real bad Id let it go.
Old Mar 21, 2010 | 10:55 PM
Boofster's Avatar
Old Mar 22, 2010 | 07:10 AM
ZeroF's Avatar
Thanks for the advice everyone, Hope to do the valve adjustment this week and recheck it.
Old Mar 22, 2010 | 07:31 AM
ZeroF's Avatar
More Info
I got a CEL about a month ago
2 Codes
Random Cylinder Misfire
Cylinder 1 Misfire Detected
I replaced spark plugs and run some fuel injector cleaner.
Code came back
Had to leave the car parked in the garage for 20 days while I was working in Hawaii.
Came back
Replaced Coilpacks and Sparkplugs again with OEM.
Cleaned Injectors
Compression Test
Here we are now.
Old Mar 22, 2010 | 07:44 AM
xeuxx's Avatar
Super Sighs.
I say do a valve adjust see what happens, sell the SC and keep going.
Do boost another day, don't get rid of the S.
