Australia & New Zealand S2000 Owners Members from the land downunder.
Does my Starter need a Service/Replacement?
Old 04-10-2018, 02:25 AM
RolanTHUNDER's Avatar
Question Does my Starter need a Service/Replacement?
Mates
So last Saturday after pushing START nothing happened. I could hear the fuel pump prime after turning the ignition on as usual then I heard what I think is the starter click/make a buzzing sound as if it was trying to turn but couldn't. I checked all the relevant fuses as per the owner's manual and found they were all intact. Battery is new and alternator checked out at 14.7 volts during idle. I did that test when I replaced my negative terminal with a new one. I kick started her and she fired up easily. After that when I push START she fires up as normal. What could have happened? Do I need to service/replace the starter? I put my hand up to the starter as best I could to try and feel if any wires were loose but I couldn't feel anything nor could I see clearly as its so tight down there without removing the alternator.
It used to grind now and then but it has not grinded since it started up again normally on Sunday. Any help, similar experiences or advice is welcomed
RolanTHUNDER
10-05-2021 04:23 AM
mikees2k
09-25-2019 09:06 PM
VIXNU
11-19-2012 03:30 AM
WarrenW
01-20-2011 04:49 PM
juventino
05-13-2008 11:59 AM
Quick Reply: Does my Starter need a Service/Replacement?
