Automotive builds Got an automotive build you want to want to document? Post it here!
DMS ultimate road/track build - Nurburgring Video now on Page 4
Old 08-04-2012, 08:46 AM
Dixon Motorsports's Avatar
Default DMS ultimate road/track build - Nurburgring Video now on Page 4
Ok we are not going to bored you with a build thread that take 2 years, this car will be our on going R&D project and we will be keep getting update with all the parts we are going to test.
We are going to spend 2 weeks building this car as myself have already booked the trip to the Ring from the 17-19 August THIS month.
Here is some progress we got so far -
Day 1 -
putting the car up and get ready for stripping -
All this will be coming off -
Getting stripped
Rear Subframe and Crash bar out
New subframe from 06 car with seam welded and powder coat -
Test fit new Bumper
More stripping -
Engine supporting by engine stand as the Front subframe is coming out -
Front Subframe -
Gearbox out -
Some new parts getting ready
My favourite Nitron 3 ways Race coilover
Our very own DMS PRO76S 3 inch single exit with dolphin tail
PRO76R Manifold with built in silencer -
Day 2 will be follow up soon
Old 08-04-2012, 11:40 AM
AndrewLin's Avatar
how much for the header?
Old 08-04-2012, 01:38 PM
s2sik's Avatar
cant wait to see more progress. that exhaust and header look nice.
Old 08-04-2012, 01:56 PM
driver #8's Avatar
that header looks great...post dyno graphs when u get this thing running
Old 08-04-2012, 02:40 PM
Islandroots's Avatar
Im feelin' that header too
Old 08-04-2012, 03:19 PM
That is our own developed header with proper CFD analysis design. It proved to give more power than the other big brand on the market after dyno test
We made that as we couldnt find anyone make a proper 3 inch 76mm system on the market so I get my engineer together to design our own version
Full 3 inch system dyno result and video is on this post https://www.s2ki.com/s2000/topic/914...lly-available/
And we also do a NA version 65mm and also proven to make more power than other big brand on the market as well. Info is on here https://www.s2ki.com/s2000/topic/922...lly-available/
Thanks
Dixon@DMS
Old 08-05-2012, 12:17 PM
Former Sponsor
Performance Rush's Avatar
Wow...very nice work guys! Lookin' forward to seeing more
Old 08-05-2012, 12:21 PM
Coolbeans's Avatar
Looks like fun!
Old 08-06-2012, 07:33 AM
Day 2
Today we have removed the Air con system, the stock radiator and derusting under the car and will apply underseal for protection.
We have also lay down most of the parts that is ready to go onto the car -
Front Subframe collars, powerflex bushes
Rear Subframe collars, Rear Diff collars, Ultra racing rear under brace
Hardrace Rear Spherical bearing damper bush -
Hardrace Rear Roll Centre adjuster -
Hardrace Steering rack reinforce bushing -
Hardrace Front Roll centre adjuster with Camber offset plate. Hardrace Spherical damper bush for front damper.
Hardrace forged drivershaft spacers, Hardrace Rear diff reinforce collars, Ultra racing rear Strut and lower subframe brace-
Powerflex Front Compliance bush with Stainless caster adjuster kit, Hardrace OEM heavy duty top ball joint and powerflex suspension arms bushes
Hardrace harden tie rods and spherical tie rod ends, powerflex ARB bush
Ultra racing Front subframe 6 points brace with rear subframe 4 point brace.
Ultra Racing Chassis brace -
Front we have Mishimoto Radiator with Fan, Mocal Oil cooler, AP Racing cailper with Dixcel FCR Slot disk and Dixcel Type RA front pad.
AP Racing caliper with Dixcel disk and pad -
AP Racing Brake Bias
Hardrace rear Toe arm, Dixcel Rear FCR Plain disk, Volk CE28 with AD08, Nitrons, Hardrace RCA and Hardrace OEM heavy duty top ball joint
Hardrace Heavy duty top arm ball joint -
Seam welded Front subframe fitting with Subframe collar, Steering rack bush kit
Password JDM Dry carbon heat shield
4.4 final drive
Main set of wheel Volk CE28 with AD08
Spare set of wheel, Work Emotion with AD08
that it for today, will post more update tomorrow
Dixon@DMS
Old 08-06-2012, 08:42 AM
sdosmill's Avatar
WOW! awesome build!
Quick Reply: DMS ultimate road/track build - Nurburgring Video now on Page 4
