Automotive builds Got an automotive build you want to want to document? Post it here!
Sirbikealot7's Auction car rebuild and Function>Form quest for Lap times
Old 09-05-2018, 03:35 PM
  #101
s2000Junky's Avatar
Originally Posted by sirbikealot7
But yes I'm still on NT01s. As far as I know the S2000 record is held by Jared (gearhead) at a 1:48 on Hoosiers. My goal is to beat that time on NT01s this year, but we'll see. I'm at about 430whp running E40 mix is where I'm typically at on the track. The car makes roughly 500whp on E85 and 460whp on E55.
As far as I know this is still correct. He is supercharged making 350whp if i recall my conversation with him accurately. So just from that alone id say entirely possible you have a car that can beat his time. There is a lot of time you can pick up just due to the amount of straits on that track when you have power. Corning speed isn't going to account for nearly as much when you are already maximize in grip and line choice which sounds like you are, so most all your time at this point will be gained form added power/ strait line capitalization.
My second time out to the Ridge I ran a 2.01.25 with a stock weight/power s2k with 255/295 stagger on old kumo xs summers. 122mph is the best I could get before braking into turn 1.
Old 09-05-2018, 05:59 PM
  #102
warmmilk's Avatar
My second time out to the Ridge I ran a 2.01.25 with a stock weight/power s2k with 255/295 stagger on old kumo xs summers. 122mph is the best I could get before breaking into turn 1.
he already matched Jared's time, but I disagree about "a lot" of time in the straights... you gotta have buckets of power more for that to be a clear advantage.. generally R7's are about 2-4 seconds quicker than NT01's all else being equalish... in addition to the extra 100hp sirbikealot also has bigger tires and pretty quite a bit more aggressive aero... so when you factor that in, the extra power is really 1-2 seconds of that equation...
The main thing about a power advantage is that it means you have to brake sooner. what really counts around the track is average speed. so car A could hit 130 on a straight and car B can hit 100, but car B can go way deeper into the turn. I'm not saying that levels things out, but it brings that average speed a lot closer than one might expect just looking at hp figures
Old 09-05-2018, 06:15 PM
  #103
s2000Junky's Avatar
Yeah, but ive gone .2 sec quicker then you so
Old 09-05-2018, 06:25 PM
  #104
Bullwings's Avatar
Awesome build. I really like where this has gone.
Another non-custom non-forged wheel option to maximize the rubber under those massive fenders:
18x11 +52 Apex ARC-8
https://www.apexraceparts.com/wheels...ang-wheel.html
You can probably run 305/35s NT-01s on there with the massive amount of room those fenders give you.
Old 09-05-2018, 11:42 PM
  #105
warmmilk's Avatar
with about 50-60 more hp and going 8 mph faster on the front straight and all the pad knockback so
hahaha
Old 09-06-2018, 04:40 PM
  #106
sirbikealot7's Avatar
Thanks for the link! Good idea
Old 09-06-2018, 04:49 PM
  #107
And yeah, I'm doing 140mph at the end of the straight. I'm pretty confident that if I bolted hoosiers on the car it would turn :45s. I've got another double day coming up September 21/22 so we'll see how it goes
Old 09-12-2018, 12:53 PM
  #108
ateens4's Avatar
First off I want to say that I admire the fact that you gave this S2000 a second chance at life and I hope that many others will follow suit. And awesome track build!
Old 09-25-2018, 11:11 AM
  #109
GEARHEAD's Avatar
What a beast! 45's should be no problem on Hoosiers. My fastest time was a 1:46.8 but that was before the repave at turn 13 which slowed me down about a second. The setup at that time was 245 Hoosiers (17 x 9's) and 325 whp (dynojet) and small splitter/small GTC-200 wing. My max speed was 137 before T1. I'm surprised your max isn't higher with over 100 whp more although you likely have a bit more drag due to the larger wing and flares.
Nice job on the car and driving. Hope to see you on the track next year.
Old 10-01-2018, 04:02 PM
  #110
Thanks, Jared! I managed to do two identical laps at 1:47.88 this last outing, unfortunately battling rain I didn't get much change to go faster. We aren't on a even playing field anymore regarding tire width and compound but I haven't seen anyone who's even near us at this point which I'm pretty happy about haha. I'm sure my aero is far from optimized, that being said, I didn't lose any max MPH with the addition of the flares and wider tires, so drag must not be that different, guess the dive planes/spats are working though they are likely undersized now. Comparatively I only managed 120 mph with the car NA and the old aero. Hows the J32 going so far? Think it'll be able to make near the same power as your SC kit did? Look forward to meeting you too and hopefully get to play around at the Ridge together!
Quick Reply: Sirbikealot7's Auction car rebuild and Function>Form quest for Lap times
