Check engine light
Originally Posted by A51_AP1,Oct 28 2008, 09:27 PM
Or you can buy a scan tool from Autozone for like $50. Or, you can get one on ebay for $20. It works fine, all you need is the code, and I can let you know which each code is. It's on here as well, but I cant find the link...
thx
SY
They can work with almost all cars, but sometimes the codes are not descriptive.. A dealer scanner can tell exacly what the problem is and what to do to fix..
These scanners may just say vaccum leak, or something like that..
But ussually you can tell what it is after you read the code..
^^Thats exactly correct, the cheaper ones will only tell you the CEL code, but the more expensive you get (Snap-On scan tool readers go from $500-$1500), and have more features. A standard one is pretty cheap and you should be able to search for the thread that describes all the error codes. I also have a PDF file of the Helms manual if you need it. I can email it if you'd like.
All of the code readers and scanners will give you a code number, but not always a good description of the problem. However, if you have the service manual for your car, there should be a list of codes with their meanings and a sequence of steps to diagnose each one.
01S2KSA
15
Feb 17, 2011 06:55 PM
