Steering wheel not centered after alignment
Just got a fresh alignment done at Auto Innovations, and my steering wheel is not exactly centered. Obviously everything was done to the specs I requested, but is this just a problem of the steering wheel not quite being centered when the alignment was done? I wasn't sitting in the car when it was aligned, but I am not that heavy so I can't imagine that being the issue. Basically while driving the car straight on the freeway the wheel is angled a tiny amount to the left, letting go of the wheel and it doesn't seem to pull in any direction.
Is it possible that something else might be damaged? Should I go back and sit in the car on the alignment rack, making sure the wheel is properly centered while they adjust?
Thanks.
Update:
Stopped by Auto Innovations today and they got it dialed in just right for me. I still get the usual behavior when driving on the freeway due to the crown in the road, but it is much more subtle now and when on a flat road everything is nice and square up. I also had them increase caster from 6.0 to 6.5 and what a nice difference that makes in the weight of the steering with a staggered setup. I told them I would gladly pay for the cost of another alignment since I decided to change the caster specs but Orlando was nice enough to make the changes for free. Big thumbs up for AI. Highly recommended.
Thanks again for everyone's help and information.
Thanks.
Update:
If I was to guess, because it has happened to me before, the steering wheel might have been slightly off-center when everything was aligned. I don't think it had to do with you being in the seat or not at the time. I bet if you take it back they'll fix it right up.
Hoping that's the case, but they align many S2000s and it doesn't seem like this is a common problem. I have never really had any majors offs other than the one at Thill, but even that one was pretty mild until I ran over a large bolt. I will setup another appointment with them to have them check it out. It is nothing dramatic but it drives me insane while cruising on the freeway and other roads I know are flat and I have not had issues with in the past.
This reminds me I need to schedule an appointment as well. I'm not too happy with my UK spec alignment, it understeers pretty bad. Time for a change! Hopefully they can squeeze me in before Thunderhill next month.
I wonder how much the rear toe can change under braking and other situations?
max camber is good for turn in but affects high speed stability. If its off center its due to the flex in the bushings and play. usually they turn it left and right so the play is same left and right and center it.
if it bothers you just bring it back
Just Because The Steering Wheel Is Off A Bit Doesn't Mean Ur Alignment Is Off. They Should Be Able To Straighten It Out For You NO Problem. If Not Pm Me I Can Help You Out Or If You Have A Jack,Colored Sharpie And Some Wrenches I Can Guide YoU On Doing It Yourself
Auto Innovations has been great for me, couldn't recommend them more.
