car battery failure warning
Drill a hole in it. It will fail shortly
Seriously, what type of failure are you concerned about? Most of my car batteries seemed to just up and die. The glass mat battery on the other hand seemed to have less and less cranking power, especially in the winter.
Behavior is the best way to know outside of just checking it. Slow, weak starts (summer heat kills batteries, winter cold highlights lack of CCA), dimming electronics while in operation, both good ways to tell. Also, age, and some batteries have visual indicators on them.
The first time I think the car cranks one extra time before starting or cranks different than I remember, I go to the parts store, they hook up a meter, it tells you everything about the battery. That usually tells me if I have a bad battery or need to check a ground. They do it for free and it takes two minutes.
edit
exactly, they even will print out a sheet with CCA and whatnot at the local big box parts store for free.
edit
Have to run a load test (what shops do) to find a battery that is just nearing the end of its life from natural causes. An ordinary voltage measurement can look fine (13-odd Volts) but then drop to nothing when the battery is under load (putting out decent current).
Jeremy Clarkson
Sep 11, 2015 10:08 AM
s2kjoel
Apr 23, 2014 06:47 AM
