The temp. setting is stuck at HOT
Old Jun 12, 2006 | 11:17 AM
xviper's Avatar
Originally Posted by WhiteS2k,Jun 12 2006, 11:45 AM
I think the cable is probably coming loose at the knob end
Bummer! If it was at the engine bay end, that would be easy.
Old Jun 12, 2006 | 02:08 PM
DouglaS2000's Avatar
Originally Posted by WhiteS2k,Jun 12 2006, 06:45 PM
As the outside temperature slowly climbed up to the 80's, I finally looked under the hood and traced the operations of the knob to the valve. Seems the cable is not moving a lot when the temperature setting knob is rotated. I think the cable is probably coming loose at the knob end and it will cost big bucks to disassemble the dash to fix the cable. For now, I just manually set the valve to turn off the heat (the valve still moves). I guess I will manually turn it back on when winter comes.
Thanks, xviper, for all your help with this.
I had the same gen Accord. The knob is a very common item to crack and break. Just pull the knob off and see if it is indeed cracked. If it is, then just replace it. Should work as good as new. Let me stress that the plastic knob that you turn to change the temp is almost ALWAYS the culprit. Friend also had that same problem, 93 Accord SE. His knob broke twice! Cheapy plastics I tell ya.
Old Jun 12, 2006 | 02:12 PM
http://www.hondaautomotiveparts.com/auto/j...OL+%28BUTTON%29
Part 11 in that diagram is what I am referring to. $5 to replace.
Old Jun 12, 2006 | 04:12 PM
WhiteS2k's Avatar
Thanks. Are you saying that I can just pull it and it'll come out without disassembling the dash? I'll give it a try (again, when I have time, this is not a very high priority item for me since the temporary fix is working fine). Thanks a lot for your suggestions, Douglas.
Old Jun 12, 2006 | 07:25 PM
no_really's Avatar
Banned
the knob is the likely culprit, and cheap to fix. Do that first. It just pulls off. If that isn't the problem, it is the assembly behind it, which probably isn't all that hard to remove, if you have the patience of a saint and the tools of a carpenter (no miracles should be needed, just an assortment of screwdrivers).
Old Jun 17, 2006 | 11:03 PM
WhiteS2k's Avatar
Thanks for everyone's help. I spent $5 on the knob and now everything works fine. Thanks again.
Old Jun 18, 2006 | 01:44 AM
no_really's Avatar
Banned
good to hear
Old Jun 18, 2006 | 02:27 AM
Sweet..
F1SpeedTrap
Sep 28, 2011 10:02 AM
Pointblank
Feb 2, 2009 04:05 PM
AeroS2000
Jun 24, 2008 03:14 PM
nte11igence
Aug 27, 2007 01:27 PM
yf69
Oct 14, 2001 04:33 PM
