Worst oil Filter placement
#22
Worst has to be the 1.8l Mazda Miatas. You had to either jack the car up and remove the whole plastic air flow sheet from under the car, OR reach down between the intake manifold and engine (on a warm/hot engine) to unscrew it a 1/8" turn at a time.
#23
it can be removed from the top or the bottom with relative ease.
lexus is300 auto trans motor oil filter sits under the intake mani, you can't get it out from under and you get it from the top, you have to tip the filter over(yes, the oil will be on everything under the intake mani, which is a bitch to clean) at an angle to pull it clean of the intake mani.
the easiest would be all the BMW's, the canister is right at your face with a big arse bolt
#26
Originally Posted by MATT DAMOND,Jun 20 2009, 11:39 AM
On my 944 turbo, oil spills everywhere and there is very little space to get it out, once it's removed.
#29
I can't even get at the filter on my 03 Tacoma. It amazed me when I saw how they redisigned the newer engines to have the filter right on the top of the engine. It went from an unbelivably bad design to an excellent design.
