Xenon headlight problem
Old Aug 8, 2005 | 06:48 PM
mchoi02's Avatar
Default Xenon headlight problem
Hi,
I recently sold my S2000 and purchased a 2001 911.
I'm posting on this board b/c I've always received prompt and helpful response compared to other forums.
I noticed one of the Xenon headlights on the 911 didn't go on when I turn it on. Only after I turn on and off several times does it go on. It almost seem like one of the headlight is 'somewhat' blown out.
Has anyone experienced something similiar?.... Is it time to replace the bulb, change the Xenon controller or clean the connections?...... Any help/feedback would be appreciated.
Thank you.
Old Aug 8, 2005 | 06:54 PM
Fasttimes!!'s Avatar
It seems there is a loose connection from what you are describing. If the unit is burned out its just that, burned out. It will NOT work at all. Vibrations on the car will make the contacts touch causing the light to work then another vibration will work it loose. Hence working sometimes.
Check the connections first ensuring they are clean and touching.
Old Aug 8, 2005 | 07:49 PM
Slows2k's Avatar
Moving to Car talk, not an S2000 Question
Old Aug 9, 2005 | 11:40 AM
hpark's Avatar
semi related, i love the 996 xenons.......they are WHITE
Old Aug 9, 2005 | 11:56 AM
steve c's Avatar
Could also be the ballast. Most likely a faulty switch or loose connection.
Old Aug 9, 2005 | 04:07 PM
steve c's Avatar
Forgot to mention, do you have the build sheet for your 911? Lots of folks added the Litronics themselves. Some used non OEM parts, some used refurbished control modules -- I have read of a few folks have issues like yours when the control module went south.
Old Aug 9, 2005 | 07:34 PM
mchoi02's Avatar
Thanks for sharing the information..... The xenon was OEM as specified on the sticker...... hopefully I won't have to replace the controller.
r8byb
Feb 16, 2011 02:31 PM
Fizoust
Jan 12, 2010 09:54 AM
RedhotS2k5188
Jul 23, 2009 06:34 PM
sthestazn
Aug 24, 2006 06:10 PM
s2kev
May 21, 2006 01:22 PM
