Boosting the radio reception
My missus has a skoda fabia and her radio reception is woefull to say the least and it is pissing her off ( please help ) what I'm wondering is what do I check on the car and is there any way of boosting the reception?
Cheers for any replies
on my 95 civic, i went with an active ariel.
vastly improved reception over the built-in passive unit.
not sure if the skoda is active, but maybe fuse has blown/power wire is no longer connected?
maybe the cable has become disconnected on the back of the radio?
More details please.
Does the Skoda have an amplified shark's fin like other vages? If so, check the power supply to it is on & the connections back are good.
If we're talking DAB/+, I understand the vages moved from a sharksfin to a window jobbie & there's little one can do other than drill a hole in it & put in a proper twig.
Yes, the earlier cars had a regular twig.
There may be a screw on the back of the headset in order to attenuate it; you could try that.
Since accessing the twig means losing the rear of the headlining, you might want to run it down to your local ICE centre for more diagnosis/fettling.
Basically a powered replacement twig. Might as well get a DAB+ HU while you're in there!
There's no DAB anywhere; they have the transmitters turned up to 0.
Actually, that may be your problem; they're turning down the analogue to force you to buy a DAB+ unit.
Even though there's no DAB in Shetland...
If the zombies are involved, it's bound go wrong.
chillout18
Jun 19, 2009 11:04 PM
