Civic type R interior light problem
Old Mar 6, 2013 | 09:36 AM
Sean_2000's Avatar
Default Civic type R interior light problem
Hay all.
My partners tyre R interior lights come on with the button but not when you open the doors.
Where are the switches?
Cheers all
Old Mar 6, 2013 | 09:40 AM
RattyS2k's Avatar
Might say in the handbook which will be in the secret compartment
Old Mar 6, 2013 | 09:43 AM
Nick Graves's Avatar
Where they are on the S2000 and they can get 'bent' the same if you slam the belt buckle in the door?
Old Mar 6, 2013 | 09:45 AM
Sean_2000's Avatar
Yeah but on the S you can enable and disable it using the slider.
The civic just has push in switches.
Is there someone to switch auto on and off?
Any not another secret compartment
Old Mar 6, 2013 | 09:54 AM
Ah - ISWYM: I thought you mean the door buttons & not the light buttons.
There are map reading lights over the mirror & there is a slider on the dome light behind the sunroof. The latter is door controlled.
Well they were - actually you didn't state the chassis code & they might have changed it since the EK9...
Old Mar 6, 2013 | 09:55 AM
Sean_2000's Avatar
Hay thank you I will look harder.
It's the 2003 with the gear knob on the dash
Old Mar 6, 2013 | 10:13 AM
Oh, an EP3:
Wot I done said.
Old Mar 6, 2013 | 11:46 AM
Sean_2000's Avatar
Thank you, I got in the car and checked it out and indeed there is a light just behind the driver and passenger seat.
Does not work in the on position but after a few taps it comes on with the switch not fully on ON
In the middle position nothing happens when I open the doors.
I think I need to take it apart and check it out
Old Mar 6, 2013 | 11:54 AM
No problemo - chances are the festoon blub is dying, or the contacts need cleaning on the switch.
Or else you're shorting it across the poles (racist) to make it work and you've a blown fuse. But then the radio doesn't work...
The 'on' has its own supply and the doors switch are a separate supply. If it fades off, via the canbus.
It'll probably work fine if you take it apart & put it together again.
s2konroids
Oct 14, 2011 11:18 AM
lilmrtinnie
Sep 2, 2009 06:03 AM
Peter Pantless
Jun 26, 2008 01:56 PM
tomatokinglover
Apr 21, 2008 04:25 AM
S2KNJ
Jul 14, 2004 09:01 AM
