Lockdown lowdown
Old Jun 9, 2020 | 01:29 PM
  #121
Nottm_S2's Avatar
modern autos are great.. our next fam car will be auto. Mainly cause she cant use a clutch with any sympathy. And i dont mean traffic light GP, i mean riding the bastard like it's your favourite horse
Old Jun 9, 2020 | 10:08 PM
  #122
unclefester's Avatar
Originally Posted by martin j
I'm not able to work out my wife's reasoning, I've just learned not to argue and keep breathing, I may just bring a demo home and take her out in it and then tell her to drive back, and see where it goes from there.
That's how i'd approach it - or rent one for a day out and pretend you've done your arm / neck / knee in so she has to drive back.
@arsie Those Smart boxes are fine if you lift off the gas just before its about to change gear - we've got the 90bhp turbo one at work and it is s a great little thing to throw about.
Old Jun 10, 2020 | 12:24 AM
  #123
arsie's Avatar
Make sure you do your right knee in, not the left one, they're no daft @martin j
I think that must be the 'new' model 2014 on: the W451 is only a single clutch affair. Lift off still helps @unclefester
Yes knocks along, 0-62 in 10.7 seconds for ours though being the cabrio it will be a bit less. Son in law was quite surprised when he borrowed it
Old Jun 10, 2020 | 02:28 AM
  #124
Nottm_S2's Avatar
@arsie yesterday
Old Jun 13, 2020 | 08:25 AM
  #125
Nottm_S2's Avatar
How many weeks in and still not happy with the BM brakes
I had the wheels off and went for a bleed where the pipe was above the nipple and the bottle sat on top of the wishbone
No air came out
What I did notice was one side is very loose without pedal so will whip that one off and take a look at the dust boot to ensure its seated ok
Lockdown pitq
Old Jun 13, 2020 | 10:22 AM
  #126
arsie's Avatar
Excellent vid @Nottm_S2 not sure if the engine is up front in that steroidal Smart or still in the back. All I can see there is a battery.
edit: perhaps the time has come to lob the BM into the dealer to fix. Why learn the hard way on a car you're going to move on?
Old Jun 14, 2020 | 05:25 AM
  #127
Nottm_S2's Avatar
Noob admission
I put the retaining clips on wrong, the pedal travel was due to the caliper not sat correctly due to that clip and so taking all the pedal travel before pads met disc.. I reversed both and pedal is now perfect. Twat
Old Jun 14, 2020 | 06:17 AM
  #128
martin j's Avatar
Is that picture of it fitted the wrong way? should the clip be sytting against the pad then?
Old Jun 14, 2020 | 06:47 AM
  #129
Nottm_S2's Avatar
Hopefully that is the right way
The caliper sits on sliding pins and it's a loose fit, that clip pulls the caliper body round to square it against the disc
Because I had them off for a long time and didn't ponder that clip I put it on with the tabs outside (from the hub) and it pulled the caliper off square.. tit
Old Jun 14, 2020 | 07:20 AM
  #130
https://redeyegarage.com/blogs/news/...brake-calipers
As shown here - now you have it the correct way.
Tw@t
