very upset with the S
Old May 22, 2010 | 12:41 PM
young buck's Avatar
Originally Posted by platinumSTATUs2k,May 22 2010, 09:31 AM
it's ok, the car was built for curves...
Old May 22, 2010 | 07:38 PM
NAILBOMB's Avatar
Do you have any body mods causing aero drag?
If you're concerned that your down on power take it along with a stock s2k
to a dyno and find out.
Old May 22, 2010 | 09:29 PM
ArchAngel2K's Avatar
the only aero mod i have as of now is a spoon rear diffuser im going to do a compression check tomorrow and possibly take her over to epic motorsports and tune the AEM 2. i think it is a compression issue. what is the compression suppose to be
Old May 22, 2010 | 09:46 PM
trebor8915's Avatar
I think 240ps but i'm not sure.
Old May 22, 2010 | 10:29 PM
well ill give her a look see tomorrow and pray its not a compression issue but more of a you have all bolt ons now you need a tune issue
Old May 23, 2010 | 04:12 AM
Dressed2Kill's Avatar
Originally Posted by ArchAngel2K,May 22 2010, 04:35 PM
2.5 60ft
6.56 330 ft
9.8 1/8 mile
76.41 1/8 mph
15.00 et
95.52 mph
With a 2.5 60ft a 15.0 is not a bad time. Your 60ft time affects your 1/4 mile time dramatically. i f you got that 60ft time down to a 1.9-1.8 (a good 60ft) you would be running in the 13's I bet.
Old May 23, 2010 | 06:03 AM
mlc's Avatar
mlc
The main thing with the compression test is that they are even across all of the cylinders. So if 3 or 220 and one is 200 that is an issue. There really isn't a number because the conditions can be way different.
Kevin
Old May 23, 2010 | 06:05 AM
krshultz's Avatar
How are you launching, and are you on street tires?
When I launch mine at a Pro Solo (Hoosier A6s), I rev the motor up to x RPM (where X depends on surface conditions) and sidestep the clutch. At Toledo in 2008, we were doing it at 7500rpm. Most events this is how I launch it, but it's especially important at Pro Solos. Best 60' time I've managed was a 1.9. I find launching the car very tricky.
Old May 23, 2010 | 06:37 AM
ricosuave's Avatar
the 4.77 gears are causing you do an extra shift compared to stock gearing. that's probably where you're losing time.
Old May 23, 2010 | 07:34 AM
SgtB's Avatar
How fast are your shifts? I don't power shift, but I shift as fast as possible. You should be low 14's. 14.1x is about right for a decent run.
