Wideband Install
Old Aug 23, 2011 | 04:32 AM
SCole1989's Avatar
Default Wideband Install
Im looking to install a wideband AF gauge and instead of going through trial and error by myself, figured id see if anyone has done it before and would help me.
Ill buy you beer and lunch.
Old Aug 23, 2011 | 05:13 AM
S2000Shifter's Avatar
If you're in cola, I could help. Which wideband did you go with?
Old Aug 23, 2011 | 06:11 AM
SCole1989's Avatar
Havent bought it yet. Ive got a friend selling the AEM but I like the look of ProSport Gauge
I will be buying one.
Old Aug 23, 2011 | 07:03 AM
K1LL3R 1NS1D3's Avatar
I installed mine. I can help you. Should have a lift come this weekend so thatll make it even easier. Your gonna need a welder to weld in the bung for the sensor so this isnt a DIY unless you have a welder. I got the Innovate xd-16 kit. Way better than the AEM wideband but you can research and see what you like and whats good for you.
Old Aug 29, 2011 | 03:15 PM
s2kbfast's Avatar
I've got one now that needs installation. There is a place in sumter than I believe can do the welding work. You can get a s.s nut from any hardware store that carries them right? Then have someone cut a hole and weld it in right? Also, where do you route the O2 sensor wire?
Old Aug 29, 2011 | 05:27 PM
/\ you need an o2 sensor bung. you can get them off ebay or a local place maybe. i have an extra one also if you need it, i could mail it and it'd be there overnight im sure.
Old Aug 29, 2011 | 10:28 PM
SgtB's Avatar
You can use a 18x1.5mm nut too. Fastenal should have one.
Old Aug 31, 2011 | 09:57 AM
Clemsons2k's Avatar
I installed the Innovate LC-1 on my car successfully and can give you help if you go that route.
markforrester99
Apr 7, 2019 11:01 PM
jb34304
May 24, 2010 02:26 PM
whiteflash
Mar 11, 2010 09:53 PM
seoul2k
Jan 17, 2010 08:01 PM
scorchza
Sep 20, 2007 04:57 AM
