AEM wideband O2 sensor help
Old Sep 19, 2007 | 05:38 PM
scorchza's Avatar
Default AEM wideband O2 sensor help
I just installed the aem wideband A/F ratio gauge with the O2 sensor (no EMS), but the display stays at 14.8 even when driving. I rechecked the connections and everything seems good. Do I need to adjust the dial on the back? Any suggestions? Thanks.
Old Sep 19, 2007 | 06:32 PM
CourageOO7's Avatar
What pin did you use? C16 or A23? Those are the only two you are supposed to use...
GL!
Old Sep 19, 2007 | 07:26 PM
scorchza's Avatar
I don't think I need to use any pins, the product number is AVM-30-4100. The install is pretty simple, O2 sensor to gauge and gauge to power....it's just not working and I have no idea why.
Old Sep 20, 2007 | 04:57 AM
PeanutButter's Avatar
Double check and make sure the connector between the gauge and the sensor are clicked tight
Kenny_Stang
Jul 2, 2014 11:31 AM
S2-3456789-K
May 18, 2014 01:08 PM
s2knoob89
Mar 7, 2011 10:18 AM
seoul2k
Jan 17, 2010 08:01 PM
Kandys2k
May 31, 2009 05:58 PM
