Issues with handling
I've been noticing an issue with the handling on my S. The steering felt a little bit loose, but I noticed the car pushed left when accelerating and pulled right when decelerating. It's not as noticeable @ lower speeds. Could this be a problem with the suspension? Drivetrain? I haven't hit any hard bumps, and although I do tend to push the car from time to time I have never dumped the clutch/drag raced it. If you have any suggestions or have experienced anything similar, please let me know.
Originally Posted by fastD,Aug 15 2007, 09:43 AM
A search would revel that this is most often a tire pressure issue.
tire pressure probably. if that doesnt work, jack up the front of the car and look around. check for anything bent/broken/loose and make sure to check the nuts and bolts and the sway bar as well.
i am sure nothing is broken on your car, just a heads up.
good luck, and let us know
You need an alignment my friend. Loose steering is a noticable sign of the alignment going out of place on the s2000. Fill your tires with air first though before you spend alignment money.
I did check the tire pressure. It was about 2 lbs lower on the left rear tire, but there was no noticeable change. I also checked the steering coupler (both of these I found with a search). I'm scheduled to have the alignment checked out on Sat. I spun out in March and bounced the back end off an embankment (luckily only @ about 45 mph). There haven't been any alignment issues since then, but I do drive it on PA roads everyday!
most likely a tire pressure issue, happened to me once before so i can speak from experience
