Tire Pressure Adjustments
Old Mar 2, 2015 | 09:38 AM
RedCelica's Avatar
Originally Posted by Bama Dave
I run them at 32 psi but make sure that you get the tire temps up before you start driving it like you stole it!!!
This. 32 psi cold.
Old Mar 2, 2015 | 10:39 AM
kgf3076's Avatar
Originally Posted by RedCelica
This. 32 psi cold.
Yep.
Old Mar 2, 2015 | 11:02 AM
starchland's Avatar
This. 32 psi cold.
220 kpa give or take. Sounds about right
Old Mar 2, 2015 | 11:11 AM
FluKy15's Avatar
Originally Posted by starchland
Originally Posted by RedCelica' timestamp='1425321539' post='23524593
[quote name='Bama Dave' timestamp='1425225460' post='23523335']
This. 32 psi cold.
[/quote]
Oh you fancy eh
Old Mar 2, 2015 | 11:56 AM
jvf1's Avatar
Originally Posted by JFUSION
Cool, that is great info, I remember from some of my track days using chalk on the sidewalks to achieve the same effect. I'll take a peek and see if I have those little guys on my tires. Much appreciated.
Those triangles do provide a good visual reference point to see how far you are rolling over onto your sidewalls, but that is not their real purpose. They are actually there to show you where the TWI (tread wear indicator) wear bars are located in the grooves of your tread pattern to help you find them. The triangles are located opposite the wear bars.
Old Mar 2, 2015 | 12:07 PM
zeroptzero's Avatar
Originally Posted by FluKy15
Originally Posted by starchland' timestamp='1425326546' post='23524704
[quote name='RedCelica' timestamp='1425321539' post='23524593']
This. 32 psi cold.
[/quote]
Oh you fancy eh
[/quote]
I'm a psi guy
Old Mar 2, 2015 | 12:09 PM
zeroptzero's Avatar
More good info, thanks Curt. I guess we can use them as dual purpose indicators seeing as they are in a good location on the tires.
Old Mar 2, 2015 | 12:12 PM
Habitforming's Avatar
Interesting, I was always told it was dual purpose, also for what I explained above
Set to 32 cold and forget it, then!
Old Mar 2, 2015 | 12:32 PM
FluKy15's Avatar
I may use 32 cold this year, seems to be the popular thing. I went with like 28 or so last time because my tires were like 40 psi hot coming off the dragon
Old Mar 2, 2015 | 12:35 PM
starchland's Avatar
As long as you don't go over the max.
