Doing 60k service myself
Old 07-02-2007, 05:25 AM
CBSubliminal's Avatar
Default Doing 60k service myself
Hey guys and gals. I needed your opinion on the fluids and the amounts i will be using to perform this easy task. I would rather do it myself then spend 450.00 at the local honda dealer.
Oil Change- 4 quarts of Mobil 1 Synthetic 10w-30
Oil Filter- Honda oem part# 15400-pcx-004.
Transmission fluid change- 2 quarts of Honda Manual Transmission fluid.
Rear Differential Change- 1 quart of Mobil 1 75w-90.
Cabin filter pollen filter.
Does everything look correct? Thanks in advance.
Old 07-02-2007, 05:34 AM
umgrad10's Avatar
Hi, I'm going to be doing the 60k service myself too (bought the car with 53k and am at 58k now).
I've read the car takes between 5-6 quarts of oil. I'm just going to follow the diy instructions in the "under the hood" forum.
Good luck!
Old 07-02-2007, 06:53 AM
PrimoGen's Avatar
if you are doing a full oil change (new filter and everything) its more like 5.3 - 5.5 quarts
Old 07-02-2007, 07:23 AM
CaptainMike's Avatar
Mine seems to land right at 5.2 qts, but yeah, buy 6. I'd also consider silicone treating all your underbody rubber boots, bushings,and guards, I think RoadRage has a good DIY in the UTH section.
I also Shin-etsu silicone grease all my topside seals and gaskets (doors, top, hood, trunk every 30K miles.
Lots of people prefer the LE-607 straight 90 wt for the diff. I run the 75-90 mobil 1 just because it's easy to find, and I change it every 15K or so. but you really don't need a multigrade here in FL and a straight 90 is what Honda recommends.
Old 07-02-2007, 09:52 AM
Jason2089's Avatar
every time i change my oil i buy 6 quarts of mobil 1 full synthetic it is beter to have some extra on hand than not have any at all 6 quarts and you would be perfect
Old 07-02-2007, 07:28 PM
xupthree60's Avatar
just so u and every one else knows advance has mobile 1 4qt bottles on sale for 17.78
SHUG
09-06-2015 06:23 AM
GreenmanS2000
06-28-2013 02:17 PM
tomxt99
09-17-2012 11:24 AM
sourceofuncertainty
11-24-2006 09:49 AM
kush only
05-14-2003 10:51 AM
Quick Reply: Doing 60k service myself
