engine...not doing so well
Old Jan 7, 2010 | 07:22 PM
sproket13's Avatar
Default engine...not doing so well
well...for no reason, my car decided to stop working properly today. i made a thread about it, quite bothered by it all considering nothing catastrophic happened to the engine..meaning something has failed!!! here is the thread, any help appreciated
https://www.s2ki.com/forums/index.php?showtopic=756854
i will be checking compression tomorrow
Old Jan 8, 2010 | 03:01 PM
sproket13's Avatar
things looking up. checked the codes. P2647 someone mentioned a VTEC selonoid...but, would it make the car all crazy like that?
Old Jan 9, 2010 | 07:53 AM
Bandiscoot's Avatar
it can ... because if it engages VTEC at a lower RPM than designed it would cause a lean condition (valve lift and duration increase but the ecu doesn't compensate with fuel) and then a rough idle/low RPM operation. Just a guess though.
Old Jan 11, 2010 | 08:05 AM
sproket13's Avatar
what about the clanking? it really sounded like something was loose. guess im going to replace this part.
too bad the local honda dealership wants 69$ for it, when its MSRP is 60. what a bunch of scum bags.
Old Mar 22, 2013 | 02:25 PM
ajk's Avatar
ajk
Did the new solenoid fix the problem? I have the exact same issue and the dealer has no idea what to do about it!
Artric
Mar 11, 2009 09:37 PM
Killashahmafia
Dec 27, 2004 10:27 AM
clevelandscrap
Aug 30, 2004 06:57 AM
YOD88
Aug 2, 2003 10:12 AM
MeTh222
Aug 22, 2002 02:51 PM
