Thanks to Puddydad for my stage 2 Diff
Old Mar 30, 2009 | 05:31 AM
Blacknot's Avatar
Default Thanks to Puddydad for my stage 2 Diff
This pic is of the balance on the ring and LSD carrier assembly. The rear is balanced at less than a thousands of an inch true round. By taking the time to balance the rear like this it will run extremely smooth with such a accurate balance.
This pic is of the PuddyMod solid steel sleeve on the pinion. The factory crush sleeve is just to the right front for reference
This pic shows the turning torque on the flange after the PuddyMod solid steel sleeve is set. The torque is set at 12 inch pounds.
This pic shows the backlash and gear to gear pattern, backlash is set at 3 to 3.3 thousands, the pattern looks great.
This is the finished rear build, note the information on the LSD also note the excellent gear to gear contact.
Puddy diff ready for install to be back in action
My diff finally deciced to let go after 102k miles and a few autocrosses. So i contacted Puddy to fix my up with something stronger. I figured while he was in there why not do a gear? I decided i enjoy shifting and wanted something short so i went with the 4.77 and like Ben(Puddydad) told me the gear is fantastic. I huge improvement over stock for what i was looking for. Ben's service is top notch. I pulled my diff out and he had it back to me in less then a week. I'm still breaking everything in but so far it's great. The gear is nice and quiet with no whine at all. I cant say enough about the service Puddydad provided for me and the quality of work he does. I'm very lucky that he is a local member and i could deal with him personally. I highly recomend his services. He took pictures of the build and i will post them up when he emails them to me or he can chime in and post them.
Old Mar 30, 2009 | 08:19 AM
The Twanksta's Avatar
SuuWeeettt!! You gotta take me for a ride now so I can see how short they actually are!
Blacknot's Avatar
Here are the build pics to show the quality job Ben did for me
Old Mar 30, 2009 | 08:38 AM
Brownsound's Avatar
Excellent looking work! Now lets see if you can get more than a second faster than me
Old Mar 30, 2009 | 08:47 AM
Bandiscoot's Avatar
wow ... that should prove fun and interesting. Always quality from the Puddydad
congrats!
Old Mar 30, 2009 | 11:11 AM
M.A.R.C.'s Avatar
curious to know what your cruising speeds are with the 4.77's
Old Mar 30, 2009 | 11:15 AM
Brownsound's Avatar
Probably about the same
His RPMs should be 16% higher than an OEM AP2 any given speed/gear.
Old Mar 30, 2009 | 11:52 AM
ITBs2k's Avatar
Ben is a good guy. I hope I can get him to make build me one down the road.
S2KERRP2
Feb 15, 2018 07:12 AM
staylor725
Jun 16, 2014 05:40 PM
Carl Bourbon
Oct 13, 2013 03:05 PM
topekoms
Feb 21, 2007 01:46 PM
