Is there any way to fix a CEL?
Old Dec 23, 2007 | 03:45 PM
1outs2kisback's Avatar
Default Is there any way to fix a CEL?
Is there any way to fix a CEL without going to Honda? Help me out Guys!
Old Dec 23, 2007 | 03:54 PM
zdave87's Avatar
Member
You need to run a code first (go to AuoZone etc) they will pull the code for you.
If the CEL is constantly flashing--DO NOT DRIVE THE CAR!! Have it towed to Honda or your mechanic.
Old Dec 23, 2007 | 03:59 PM
negcamber's Avatar
Go to Advanced Autoparts or Autozone and get the code read for free. If you have an 00-01 the parts guy will need to know the OBDII port is above the passenger footwell next to the radio...other years are on the drivers side. They can clear the code once they pull the info.
Come back and tell us the code so we can help diagnose the issue causing the CEL.
Otherwise if you just want to clear it...you can reset the ECU:
https://www.s2ki.com/forums/index.php?act=S...0#entry12038951
Old Dec 23, 2007 | 04:19 PM
jphish's Avatar
Please don't reset the CEL if you don't know the code.
Old Dec 23, 2007 | 04:37 PM
speedworksracing's Avatar
if you are in the orlando area I can scan it for you too.
Old Dec 23, 2007 | 08:24 PM
Thanks guys, got the CEL from my O2 sensor. The reset worked great and I put my cat back...Berk test pipe and Spugen exhaust tooooo loud!!
Old Dec 24, 2007 | 03:22 AM
zdave87's Avatar
Member
If you get another CEL in the next couple of days, get it scanned and get the codes.
Old Dec 24, 2007 | 07:52 AM
negcamber's Avatar
^^ He got the CEL from installing a TP without the mechanical o2 simulator.
Which is why I gave him just the instructions to clear only...I figured that if he had a problem with the car, he would have described it. So, I figured he may already know what caused the CEL...in this case, the TP.
Old Dec 24, 2007 | 04:47 PM
Bandiscoot's Avatar
such a know-it-all ... that's what discludes you from being a CO!
NEXT!
totally kidding of course!
TigerStyle
Feb 9, 2011 05:09 AM
1nate7
Oct 2, 2009 05:03 PM
cmn1882
Feb 24, 2007 06:52 PM
nightcrawler7188
Jun 5, 2006 05:21 PM
