Heated seats in the summer? Need help!
So here we go, I went to turn on my seats the other day because we have had some semi cool nights and the passenger seat works fine but the driver side seat won't turn on. I wasn't part of the wiring group I was part of the brawn instead of brains if you will. Where were these wired to? Cause my head unit does not work now as well.
And also I have tried the seats since then and the weird thing is the light on the button would come on dim then another start would not come on at all. Now it won't come whatsoever
Sounds to me like a loose wire. The seat wiring is separate from the radio. It runs from the switch thru the center tunnel. It comes out behind the drivers side panel that is removable. This should be by your right knee as you sit in the car. You should See a black and red wire that run from there to your fuse box. The seats are wired into the accessory spade that turns off when you have the ignition off. Hope that helps
