Gateway S2000 Owners Members for St. Louis MO and area.
Help with Oil Pan !?
Old Jun 20, 2010 | 06:08 PM
ro0tbeer's Avatar
Default Help with Oil Pan !?
Valvoline did an oil change about a year and a half ago and stripped the threading on the inside of my oil pan plug. i have tried a helicoil to rethread it and it hasnt helped. the bolt it tightened to specs and appears nothing is wrong, but it STILL LEAKS it has gotten worse and i am in need of some advice.
any suggestions?
i found a race oil pan for 250 online but i would rather try to repair this first before going that route
Old Jun 20, 2010 | 07:30 PM
mpetus's Avatar
Basics first- are you using an aluminum crush washer to seal it?
Old Jun 21, 2010 | 06:26 AM
ro0tbeer's Avatar
mpetus,
I believe I am using an aluminum crush washer. But would that make that big of a difference and make it leak that much ?
Old Jun 21, 2010 | 06:58 AM
8BALL's Avatar
Originally Posted by ro0tbeer,Jun 21 2010, 08:26 AM
mpetus,
It would. If you are using the washer, did you/they use a new washer or reuse the old? If reuse, leaking is very possible
Old Jun 21, 2010 | 07:07 AM
ro0tbeer's Avatar
I am waiting to hear back from my mechanic to confirm we used a new washer. I am almost positive that we have replaced it with a new one. Lets say we have, which is likely. What would be the next step ?
Old Jun 21, 2010 | 07:18 AM
Su2uKa's Avatar
Sounds like you torqued the bolt correctly - if so, that and a new washer each time should do it...
New Honda oil pan can be had for ~$212 (according to the College Hills Honda website) so can't see that a "race oil pan for 250 online" would be worth it...
Did Valvoline compensate you for stripping the thread?
Old Jun 21, 2010 | 07:34 AM
ro0tbeer's Avatar
Confirmed that we used a new aluminum crush washer
I didnt notice the leak until about a month or so later, and i brought it to my mechanic to look at and he took the bolt out to examine it. So since he did that, they wont cover the repair.
nashpotatoes21
Apr 17, 2018 05:23 PM
Peti
Dec 17, 2014 04:48 PM
s2kbtos
Mar 14, 2013 09:39 PM
T-Smac
Jun 3, 2011 10:47 AM
hun6over
Jul 30, 2008 05:19 PM
