oil drain hole
Old Mar 14, 2013 | 07:00 PM
s2kbtos's Avatar
Default oil drain hole
So i was changing the oil the other and the thread on the oil pan has been damaged a little. There is a certain point where the bolt just spins.... It is currently dripping a little oil from there.
How can i fix this problem?
Old Mar 14, 2013 | 08:15 PM
CrAzYNeSs's Avatar
Member
You need to get the oil drain hole on the oil pain re-threaded - sounds like you stripped it. Other option is to get a new oil pan.
Old Mar 14, 2013 | 09:06 PM
rob-2's Avatar
This or if he's cheap run a slightly larger bolt and let it 're-thread' the pan itself. Not ideal but quick and easy.
Old Mar 14, 2013 | 09:39 PM
franky's Avatar
I would just rethread it. Take your drain bolt to autozone, oreilly or napa and have them give you the right tap.
Peti
Dec 17, 2014 04:48 PM
GTS2S2K
NYC Metro Stock Exchange
May 20, 2009 06:36 AM
xviper
Apr 8, 2007 01:09 PM
Seks
Oct 23, 2004 03:17 PM
