Gateway S2000 Owners Members for St. Louis MO and area.
supercharger
Old Apr 15, 2006 | 11:43 AM
letterkills155's Avatar
Default supercharger
I want to get a supercharger but i need to know if i get one do i need to get any other mods to. and what i kind of supercharger to get money is important i want to spend no more than 4000 on the whole thing with install
Old Apr 15, 2006 | 12:21 PM
mkell's Avatar
There rally isn't anything that you NEED. You might as well get a new clutch setup becuase you will burn through your stock setup quickly. A good route that I've heard to take is to replace the stock pressure plate with an ACT heavy duty pressure plate. You will also need a new OEM throwout bearing and pilot bearing. These can be found at hardtopguy.com. Also while your dealing with the tranny, you could get a lightweight flywheel (not necessary, but a nice touch and will save $$ to do it at the same time). Anyhitng from there is really up to your wallet and wants. Headers, exhaust, and Comptech reinforced differential housing would be good next steps. I don't have the diff housing and have never had a problem - just depends on your driving style. Spark plugs may also be in order, but I'm not sure which ones.
There are a couple other Gateway members that have a blower setup and I bet the others would be happy to help with the install. That could save you alot of money right there. You can easily find a blower setup for under 4k. You should be fine $$ wise.
Old Apr 15, 2006 | 02:08 PM
d-j's Avatar
d-j
How good are you with a wrench?
Find a used kit, install it yourself w/ help...$4k is possible.
New kit, hire someone to install it...not possible for $4k. IMO
Used kit for an ap2 may be hard to find. Don
Old Apr 16, 2006 | 05:59 AM
Hondassport's Avatar
You need to PM folex and ask him this ???, he has just traveled this road...Pete
Castanza_AP1
Mar 27, 2009 06:44 PM
jdmjpms2k
Jun 2, 2008 10:09 PM
TonyY510
Aug 9, 2004 11:58 AM
JAYZS2000
Mar 26, 2004 06:56 AM
cmnsnse
Feb 13, 2001 08:46 AM
