Hawaii S2000 Owners S2000 Owners in Paradise Hawaii Owners
need help
Old Jun 3, 2011 | 09:40 AM
P3tey2's Avatar
Default need help
i posted this on the under the hood part in the forums but maybe some from here can help me out or throw me in the right direction
Update- so I got a new battery started up just right drove it tO work no problem this morning started it up with no problem so I started to drive to work while driving eps light appears out of no where cd player goes out and the cluster also but te cluster light is still lite then my head lights go out while driving I was able to drive it back home when I get there turn it off then try it again I have a click click noise is my battery getting drained? Any clue cause I thought it was the battery but I'm lost now
Yesterday I went to lunch when I came out the car was dead so I got a jump. I got to work turned it off then tried to start it nothing happen. then had a truck give me a jump then the car would idle and die maybe bad battery but I just got it when I bougt the car, got the alt benched it's in perfect condition wat do u think???
Old Jun 3, 2011 | 10:30 AM
bouford's Avatar
yikes! saw your post in the under the hood section if t's not the battery or alternator i dont know what it could be.
what electrical (if any) did you have to do with the greddy turbo?
Old Jun 3, 2011 | 11:05 AM
P3tey2's Avatar
None just gauges.. I'm gonna go and make all my grounds tighter maybe it will help scared me again this morning
Old Jun 3, 2011 | 12:23 PM
Shabadedoo's Avatar
Veteran: Army
^somehow you could have something shorting your electrical thus grounding all your power. metal to metal contact can do this. or even aluminum. you're positive terminal on you're battery is the rubber cover on there covering the entire terminal preventing it from touching the hood?
Old Jun 3, 2011 | 12:46 PM
P3tey2's Avatar
Yup.. If you think of anything els lmk cause I done about everything just need a second opinion
Old Jun 3, 2011 | 10:41 PM
markpaco's Avatar
Sounds like a bad ground. btw, I saw your car stalled up on Red Hill this evening. There was a truck parked in front of it with a couple guys looking at it.
Old Jun 3, 2011 | 11:02 PM
P3tey2's Avatar
Thanks for the heads up had to jump the car every 15 mins...it's the alt god dam
Old Jun 4, 2011 | 01:04 AM
P3tey2's Avatar
False report it was the eld???? Changed out the fuse guess I'll be checking the volts for couple days
Old Jun 4, 2011 | 02:03 AM
jzz30's Avatar
sounds like the alternator is still blown. or more like the voltage regulator. you can bench test the alternator and it will pass since it produces power but just too much of it...
SolidTypeSexy
17
Dec 28, 2012 06:20 PM
P3tey2
Jun 5, 2011 06:50 AM
jimpom23
Jan 15, 2007 01:58 AM
AirWolf
Oct 17, 2002 06:36 PM
getchastuff
Apr 16, 2002 11:12 AM
