Vert Top wind noise Adjustable?
Old Jan 10, 2005 | 06:36 AM
xxxCadillacxxx's Avatar
Default Vert Top wind noise Adjustable?
I just bought a virgin 2000 with 26K on it and i love it. Best car i ever bought.
I am having a bit of a problem with the convertible top though. When I go over 75 MPG, it howls right where it seals with the windshield. I checked out the latches and there is no adjustment in them to make them pull tighter. When i reach up and pull down on the roof a little it goes away. I just wanted to know if anyone else is having this problem and if so how they fixed it. I was thinking about making a spacer to move the female side of the latch down a little bit but id really like to know if there is a less ghetto fix out there.
Old Jan 10, 2005 | 06:44 AM
Bass's Avatar
try some shinxu grease on the seals or you could get some heat shrink and increase the width of the hooks that latch in
Old Jan 10, 2005 | 07:12 AM
Where do i get "shinxu" grease?
thetz99's Avatar
1/4 inch plastic tubing over the hooks will give you the needed tightening. Very inexpensive fix.
Old Jan 10, 2005 | 08:46 AM
Tubing worked GREAT. Thanks for the help.
Old Jan 10, 2005 | 11:58 AM
dhayner's Avatar
A more "Honda" fix would be to install the strikers used with the hardtop, as these are stronger/stiffer than the softtop ones. If the tubing works for you, though...
Old Jan 10, 2005 | 12:26 PM
pinoydarv's Avatar
I have the same problem as you. Honda is currently replacing the latch or "Strykers" are now. I will let you know if this fixes the wind noise.
Old Jan 18, 2005 | 10:18 AM
arcadence's Avatar
I had the same problems, and it seems that the latches and strikers aren't the best quailty and that is what's causing the problems. I fixed my problem by adjusting the position of the top in the up poition slighty so it stopped a bit further than normal, so when I close the top, it makes a tighter connection. However, I think both need to be replaced, and as someone else mentioned, using the hardtop strikers are better.
Old Jan 29, 2005 | 06:29 AM
S2000MO's Avatar
This is probably a stupid question, but where did you get the 1/4 plastic tubeing? My top is doing the same thing and i would like to fix it. Thanks in advance.
Old Jan 31, 2005 | 07:11 AM
2k1wolfster's Avatar
ditto, anyone have any pics of the plastic tubbing. or the stickers?
Keatre
May 7, 2009 07:25 PM
01S2Kevin
Jan 4, 2008 12:48 PM
iammike
Oct 6, 2006 08:58 AM
NVMY4N
Mar 1, 2004 11:44 AM
GR8-S2K
Nov 25, 2001 11:28 PM
