eibach springs?
Old Oct 11, 2004 | 04:00 AM
JamesB's Avatar
Default eibach springs?
I have a set of eibach springs I got off ebay. they did not come labled front and rear. they look almost the same but two are a little taller, and the other two look like they are a little thicker. so wich go in the front and wich go in the back? I am taking it to the shop in few min so i need a quick answer. thx
James
Old Oct 11, 2004 | 05:19 AM
rlaifatt's Avatar
The spring rate should be printed in white on the coil on the side, e.g.0800250425 means 8" length, 2.5" internal diameted, and 425 lb/inch rate. Stiffer or softer in front depends on your setup, but for most the softer goes in front.
Old Oct 11, 2004 | 06:42 AM
JamesB's Avatar
thx, I dont have in front of me right now. they are at the shop waiting to go on with some koni shocks. as soon as I know which go where then they will start. I askled this a while ago and some one said the bigger ones go in the front but they did not say bigger how. one set is bigger around the other 2 are taller. thx
Old Oct 11, 2004 | 07:58 AM
honda head's Avatar
Thicker ones should go at the front to cope with the higher loading of the engine.
Old Oct 11, 2004 | 09:04 AM
rlaifatt's Avatar
Stock suspension and Mugen coilovers come with the softer springs in front. The S2000 is atypical. But some people do run the stiffer springs in front.
Old Oct 11, 2004 | 10:13 AM
Ludedude's Avatar
Administrator
What higher loading? The car has an almost 50/50 weight distribution. We're not talking about some clapped out Civic here.
Old Oct 11, 2004 | 10:31 AM
kitwetzler's Avatar
And, the motion ratio is greater in the back, so to have an equivalent wheel rate, we need a stiffer spring in the rear.
Old Oct 11, 2004 | 03:48 PM
JamesB's Avatar
Thx for all the help. we got it all put together.
AP1_Silverstone
Dec 30, 2015 03:27 PM
Scottland
Mar 25, 2014 05:27 AM
ace47
Apr 5, 2010 11:27 AM
Dox
Oct 4, 2008 02:28 PM
Spike888
Aug 21, 2007 05:36 AM
