JR Filter users - oil analysis?
Old Feb 24, 2003 | 09:39 PM
FormerH22a4's Avatar
Default JR Filter users - oil analysis?
For all the JR filter users, has anyone done an oil analysis for Silicone content?
K&N is doubtful in filtering efficiencies so is the JR any better since basically they share the same philosophy of filtering.
Old Feb 25, 2003 | 11:58 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Go to www.jrfilters.com
Much more efficient than K&N.
Old Feb 25, 2003 | 02:05 PM
jguerdat's Avatar
I have had two analyses with the JR filter and the third one is in the mail. So far, there has been no problem noted (I'm down to 6k miles using Mobil 1 10W/30 and Honda oil filters):
JEFF: Lowering the oil use interval by 1,000 miles really did not make much difference in the wear levels, so if you are comfortable with these levels, you may want to continue in the 8,000-mile oil use
range. Iron continues reading high, but we think it's going to stay up there as long as you use this oil interval. The TBN read at 10.0, showing plenty of active additive left in the oil. Insolubles (oil filtration) were close to limits at 0.5%. Silicon (air filtration) looks good at 6 ppm. No fuel, moisture, or antifreeze found.
Old Feb 25, 2003 | 03:06 PM
jguerdat's Avatar
Here's the 3rd analysis (just received, with comments and comparisons on all of the analyses):
Old Feb 25, 2003 | 03:15 PM
SECRET AP1's Avatar
Jeff, where do you send your oil to be analyzed, and how expensive is it?
Thanks,
Richard
Old Feb 25, 2003 | 03:48 PM
[QUOTE]Originally posted by jguerdat
[B]I have had two analyses with the JR filter and the third one is in the mail.
Old Feb 25, 2003 | 05:09 PM
jguerdat's Avatar
I have been using Blackstone Labs at 4929 S. Lafayette St., Fort Wayne, IN 46806 (260-744-2380). It was a lab that others here have used and someone arranged supposedly better rates for the group. You might want to do a search on the threads but I've been using them for the past year or so.
I don't recall the exact charge but it's ~$20 for the basic analysis and $10 more for the advanced work useful for extended change intervals afforded by synthetic oils.
Old Feb 25, 2003 | 05:13 PM
jguerdat's Avatar
Originally posted by FormerH22a4
That is excellent, what is your air environment like? Is it dusty where you are? Do you drive in the winter?
I'm in western NY (Rochester's between Buffalo and Syracuse) so the climate is temperate. I autocross and did about 12 events this summer with temps as high as 90. It's not dusty but we had little rain this summer so dust was probably above average. I do drive in the winter but I don't change tires, limiting my winter driving to dry days. That leads to dry road salt being blown around, sometimes causing a noticeable haze.
So, not particularly dusty - I'd guess more or less like your climate...
Old Feb 25, 2003 | 10:25 PM
Uncle Fester's Avatar
Well, if the lab results indicate everything is okay while using a JR filter, it might be time for me to order a JR filter...
Ferboi
Aug 13, 2008 02:30 PM
just1guy
Apr 4, 2008 01:20 AM
Subw00er
Aug 25, 2007 04:19 PM
ChrisfromRI
May 28, 2004 05:52 AM
bbsilver
Mar 1, 2001 04:20 PM
