Hood will not close all the way
Old Sep 28, 2003 | 02:45 PM
Luft46's Avatar
Default Hood will not close all the way
Hi all, I hope there is an easy solution to this problem. First, my '02 S2000 was deemed a total loss by my insurance after it was flooded during Hurricane Isabel, I had water (salt water) up over the center console.
I just bought a new '03 S2000, and after I got home from the dealer I noticed that the hood will not close all the way. It is latched and all, but it sticks up about 1/4 - 1/2 inch at the front.
I tried to see if the little rubber bumpers on each side were the problem, but it is not touching there I don't think. The hood seems to not be going down where the latch itself is.
I will take it back to the dealer, but if there is an easy fix I would rather do it myself. Any ideas anyone? Thanks!!
Dan
Old Sep 28, 2003 | 04:13 PM
NNY S2k's Avatar
Seeing it is a new 03 i'd take it back to the dealer just in case they need to order/replace something that is bent by chance.
Old Sep 28, 2003 | 04:30 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
It should latch twice. The hood should never be pushed closed. it should be dropped closed, from about 10-12 inches. how many times can you hear it latch if you lower it slowly?
Old Sep 28, 2003 | 04:43 PM
Luft46's Avatar
Yeah, I have always dropped the hood from about waist level too. OK, when I close it slowly, there is one click and the hood is about 1 inch from closing. Then, if you push it down more, the second latch engages. But still, the hood is higher and "jiggles" if pushed on....
Old Sep 29, 2003 | 02:33 AM
turbo_pwr's Avatar
The latch can be lowered by loosening then tightening the bolts.
Old Sep 29, 2003 | 03:01 AM
cdelena's Avatar
The rubber stoppers can also be adjusted lower.
Old Aug 8, 2010 | 05:07 PM
llckll's Avatar
To the OP, did these suggestions solve your problem? I'm experiencing the same issue.
Thanks.
Old Aug 9, 2010 | 07:59 AM
Seattle2k's Avatar
[QUOTE=llckll,Aug 8 2010, 06:07 PM] To the OP, did these suggestions solve your problem?
Salim2000
Jul 3, 2013 08:53 AM
yummyph0916
Aug 9, 2004 07:09 AM
high on nine
Mar 5, 2003 01:10 PM
wantone
Jan 25, 2002 07:47 PM
dannykim
Jan 5, 2002 11:57 AM
